Engine Is Not Right Running Under Load
engine electrical
6 replies to this topic
#1 gould1990
gould1990
  • 128 posts
  • Local Club: Bristol Mini Drifter
Posted 12 September 2014 - 02:11 PM
Hi guys and girls. i am having a problem getting my mini running well it not ran well since i had it. at the moment it run well when itnot under pressure low revs on flat and down hill. but when going up hill the engine judders and and tries to stall anyone have any suggestions. its not long had new spark plugs new ht leads coil distributor. its got to the stage where i am half tempted to take the hole engine out and rebuild.....
#2 gould1990
gould1990
  • 128 posts
Posted 13 September 2014 - 07:08 PM
bump
#3 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 13 September 2014 - 09:30 PM
you need to find the fault before pulling the engine.
check the timing and fuelling first.
#4 Earwax
Earwax
  • 489 posts
Posted 13 September 2014 - 11:48 PM
as above.
check fuel filter, fuel at the carbie, and air filter blockage.... don't discount timing either... did you gap the plugs correctly/
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 14 September 2014 - 12:43 AM
I agree with both of the above suggestions.  I particularly agree with Earwax' suggestion that you look carefully at the fuel flow.
#6 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 14 September 2014 - 10:33 PM
As above again, the engine does not need to be pulled out to check the basics first
When doing the above suggestions also check you have enough oil in the top of the carb, its a screw top called the dashpot
#7 gould1990
gould1990
  • 128 posts
Posted 22 September 2014 - 11:20 PM
can anyone suggest a needle for a 998 runnning a stage on kit with a hif 38? dont no whats in there but i ferrl it is running a 1275 needle
Also tagged with one or more of these keywords: engine, electrical
