Number Plate Led Lights
19 replies to this topic
#1 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 21 September 2014 - 09:13 PM
Hi, I've done a few searches, but hasn't really helped.
I want to do away with the number plate light housing, so looking at getting them little led ones. Does anyone have any pictures of theirs? Also which ones and where's best to get them?
Any help appreciated
Ta
Edited by megamini_jb, 21 September 2014 - 09:16 PM.
#2 RooBoonix
RooBoonix
  • 1,225 posts
Posted 21 September 2014 - 09:18 PM
I also thought of using LED's on my number plate, as the standard bulbs aren't the best. I was going to buy one of those cuttable rolls from ebay which I could then also use inside the boot. It's easy to wire and you can get waterproof ones :D
Cam.
#3 Ian Jennings
Ian Jennings
  • 28 posts
  • Local Club: BMOC
Posted 21 September 2014 - 09:28 PM
Depending on how your number plate is mounted you could bolt these onto each side of your number plate, it was just an idea.
http://www.ebay.co.u...=item51bc953ebd
Edited by Ian Jennings, 21 September 2014 - 09:28 PM.
#4 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 21 September 2014 - 09:30 PM
Oooo I like them!
#5 1984mini25
1984mini25
  • 8,785 posts
I know its not quite what you were asking, but I've replaced the standard festoon bulbs in the number plate housing with led ones, witch also fit the d shaped mk1 boot lamps.
#6 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 21 September 2014 - 09:32 PM
You could always just put the led bulbs in the stock housing ?
#7 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 21 September 2014 - 09:37 PM
Looks good mini25 :)
Cheers SA.
I'm not sold yet as it might look a bit naked without the housing, so will definitely consider LEDs to go in the housing. Thanks!
Edited by megamini_jb, 21 September 2014 - 09:38 PM.
#8 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 21 September 2014 - 09:39 PM
I have got these,as I have removed the rear light also.They seem bright enough,just hope they spread the light over all the number plate.Not fitted them yet.
#9 Ian Jennings
Ian Jennings
  • 28 posts
  • Local Club: BMOC
Posted 21 September 2014 - 09:46 PM
I'm going to be getting them as im getting a smooth boot lid, de-seeming the rear valance then mounting the number plate off the valance on custom brackets, i though those LEDs looked great for the job.
#10 rik_t
rik_t
  • 276 posts
  • Local Club: Robin Hood
Posted 22 September 2014 - 07:52 AM
I got rid of the lighting unit and mounted small LED units to the number plate:
Edited by rik_t, 22 September 2014 - 07:52 AM.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 September 2014 - 08:26 AM
Only thing you have to watch out for is rearward facing white lights...
Basically you should not be able to see the light emitting surface or element from behind the car, only the reflected light it emits. If you can it's an MOT failure.
#12 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 22 September 2014 - 08:29 AM
The little LED bolts aren't bright at all but pass an MOT :lol:  Mine has them fitted but they are useless really.
#13 rik_t
rik_t
  • 276 posts
Posted 22 September 2014 - 09:20 AM
I did have LED bolts first but they were poor so I swapped.
1016472_10152051718069611_301813581_n_zp
Edited by rik_t, 22 September 2014 - 09:21 AM.
#14 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 22 September 2014 - 09:30 AM
Yeah the bolt ones are the ones I was looking at getting.
Your mini looks awesome without the housing. I'm guessing the LEDs you have fitted now are loads better then?
Hmmm decisions
#15 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 22 September 2014 - 09:31 AM
Cheers guess works, never knew that so will remember.
