You WILL need a 2 core radiator, a standard 3 core just isn't up to the job. As taffy1967 says an electric fan is also a great idea. Vehicle Wiring Products do various sized electric fans, I had one on my 1293 (which needed a 2 core rad and a fan to keep it under control!) and it was great, never went above 80 degrees even on the hottest days.
changing radiator
deanymini
, Jul 02 2006 03:01 PM
20 replies to this topic
#16
Posted 03 July 2006 - 06:17 AM
#17
Posted 03 July 2006 - 05:35 PM
ok. ive bitten the bullet and got myself a 2 core radiator that will be fitted at jonspeed tomorrow.
i tightened up the thermostat housing and no more water is coming out of there and the bottom hose seems to be ok. my dad said that if its not coming out of the thermostat any more then its got to come out somewhere else.
would you say that is a true statement? i hope he's wrong!
#18
Posted 03 July 2006 - 05:42 PM
if it is still leaking then yes it will be coming from somewhere but if it isnt leaking then it should be fine
#19
Posted 03 July 2006 - 06:03 PM
Get them to change the bottome hose at the same time. Also, inspect the bypass hose thoroughly, and replace it if in any doubt. For the sake of a few quid for some hoses, its worth it as your engine will not last very long.
If it's not damaged already that is...!!!
#20
Posted 03 July 2006 - 08:20 PM
[quote][quote]If it's not damaged already that is...!!![/quot[/quote]
comments like that scare me!
#21
Posted 03 July 2006 - 10:43 PM
Good luck and i'm sure that 2 core rad will see your Mini running very cool as well as looking cool too!
But it was something you really should have fitted in the first place as you have a 1380cc engine, so you wouldn't rely on drums all round to stop you or poor quality cheap tyres to see you around bends at high speed, so you can't expect a bog standard radiator to cool an engine of that size either!
Oh well we learn from our mistakes I guess and I've been there myself!
