The 998 in my Mini Marcos has developed an annoying issue recently...
Once it's been sitting in traffic for a while, then you pull away, it will accelerate OK up to about 45-50mph then it splutters and cuts out, on and off, for a while before clearing.
If it's really stuck in traffic for about 10 mins or more, the car cuts out and needs to be left for around 10-15mins to "cool" before it'll start. When you try to start it before this, it'll fire for a second or two before cutting out.
Other than this, it takes a few attempts to start on cold mornings but other than this it runs fine. I do 20 miles (mostly dual carriageway) each way every workday, so it's getting a good run.
The car isn't overheating on the temp gauge, stays just below normal (and it will go higher than that as I've run it without the fan for a while to check it'll go up). I suspected a fuel issue, but last time it broke down I disconnected the hose from the carb and it was pumping fuel OK. by the way it's a single HS4 carb with a K&N conical filter on it.
I recently fitted a new exhaust manifold (end of June) and haven't had problems - driving every day - until recently. Caveat on this is that it wasn't driven much in August and early September as I had my appendix removed so couldn't drive.
I suspect the new manifold may be causing fuel vaporisation? The new pipes have a crossover where the old one was "straight" so this will have possibly caused the issue. PS - this took several hours to fit past the bulkhead so I hope the solution isn't to replace it!
Looking at the carb there doesn't seem to be a spacer on it, never had one in the time I've had it but maybe needs one now? There's not much clearance to get the filter in if there's a spacer but the bulkhead could be modified to fit.
What I've tried:
Cleaned out carb float bowl
Cleaned fuel filter
Tightened alternator belt
Checked dashpot oil
Put some petrol cleaner in with the last tankful
Flushed cooling system
I'm hoping that it'll be something as straightforward as heat shielding the fuel line (which doesn't run too close to the manifold) or putting some kind of heat shield by the carb - no-one seems to make single HS4 shields though.
Thanks for your time reading all this waffle!
