The clutch connection was just a case of adapting the pedal to work with the clutch cable.
It does sound amazing. Can't wait to get it finished and on the road :)
Ok, you had a cable connection. The cbr 1000f that i bought has an hydraulic clutch. Maybe I can use the standard hydraulic clutch pedal of the mini. Did you use the original mini dif in your setup ? Can't see on the pics how you adjust the chain tension. Do you have some more pics of the dif setup with reverse
Keep up the build ! Nice to see a bike engined mini that is not an r1 or busa
