Cylinder Head?
22 replies to this topic
#16 albo
albo
  • 204 posts
Posted 04 November 2014 - 11:16 PM
He has a 998
post jumpers who dont read clearly,then jump to the wrong conclusion,but i guess that what keeps this forum of interest
#17 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 04 November 2014 - 11:22 PM
Can someone please help me on how to do the compression ratio calculation please! That last post has completly confused me, even better if you could just sum up what i need for flat top pistons, 0.60
What CR you need I can't help with, neither can I help with calculating.
Cooperman has posted on how to do it, and AC Dodd I believe. Perhaps pm them?
All I know (from expensive experience!) Is that 5cc in a head makes a massive difference and you have to get it right.
#18 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 04 November 2014 - 11:23 PM
OK a 998 bored out +060 has a bore of 66.088mm
Stroke is 76.2mm
Which makes the single cylinder capacity 261.36cc
Piston Dish 0 cc
Head volume 23cc
Head Gasket approx 4 cc including the ring land vol.
 Which makes the combustion chamber approximately 27cc in total
That'd give you a CR of about 10.7:1
But using such big valves, you'd need to mill out an area to accommodate the valves, which would increase your combustion chamber volume and reduce your CR.
As Cooperman said, with such big valves, you won't need the extra lift from roller rockers.
Edit:
I've used this spreadsheet for working this out. You'll just need to remember the stroke of a 998 (76.2mm), and the bores are the same as 1098 engines
http://mk1-performan...web/cr_calc.xls
Edited by timmy850, 04 November 2014 - 11:25 PM.
#19 Mrpeanut
Mrpeanut
  • 1,019 posts
He has a 998
Surely 5cc in a head matters in a 998?
#20 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 04 November 2014 - 11:27 PM
He has a 998
He is offsetting the 5cc in head volume with flat top or dished pistons. this would keep overall combustion chamber volume the same
#21 Mrpeanut
Mrpeanut
  • 1,019 posts
Posted 04 November 2014 - 11:48 PM
He has a 998
I shall now go to bed!
#22 kyle9832
kyle9832
  • 434 posts
Posted 05 November 2014 - 05:56 PM
Stroke is 76.2mm
Piston Dish 0 cc
Head volume 23cc
Edit:
brilliant help thankyou! im going with 33x29 valves now as they were too big, then flat pistons with 23cc chamber, from the calculation you gave me and from the excel document, this should work well then?
Edited by kyle9832, 05 November 2014 - 06:08 PM.
#23 Cooperman
  • 23,340 posts
Posted 05 November 2014 - 08:00 PM
You still need to measure and finally machine after doing the calculations for CR.
The piston top will not come right to the block deck level at TDC and with a 998 each 0.010" down the bore is around 0.9 cc. I've seen pistons sit over 0.020" down the bores at TDC.
Do the calculation. If you are capable of doing the build you must be capable of doing the measuring and the maths. Then you will KNOW it is correct.
