Using features on my megajolt and a solid state quick react relay I've made a hard revlimiter that i'll use for launches
(To add I haven't just bought a hard revimiter board from autosport)
Edited by Gremlin, 08 November 2014 - 04:48 PM.
Posted 08 November 2014 - 04:35 PM
Posted 08 November 2014 - 05:35 PM
Posted 08 November 2014 - 05:43 PM
Posted 08 November 2014 - 06:06 PM
Posted 08 November 2014 - 06:59 PM
Posted 08 November 2014 - 09:18 PM
Haaha classsss
Does it pop and bang a lot on the limiter?
Or, does it say 5.....4......3......2......1..... Euston " IGNITION " we have lift off.....
Posted 09 November 2014 - 12:11 AM
Posted 09 November 2014 - 09:07 AM
I always thought launch control was primarily to make sure you had maximum torque, minimum clutch slip and maximum traction...
Posted 09 November 2014 - 09:33 AM
Posted 09 November 2014 - 09:49 AM
Good to see "pub points" haven't gone out of fashion.
Posted 09 November 2014 - 09:29 PM
It's not really much use on an N/A car, you can do exactly the same thing with your right foot and hold it at a set rpm to launch. for true launch control it'll need wheel speed sensors, gear sensors, efi being the main one.
I tried it years ago with my megajolt and it doesn't switch between maps quickly enough to do anything useful.
I had in mind using it for flat shifting and sitting on the line bouncing off the hard cut at 5k rpm building boost ready to launch with, with a switch on the clutch pedal to switch from normal map to the 2nd one with a lower hard cut limit.
Edited by Turbo Nick, 09 November 2014 - 09:30 PM.
Posted 10 November 2014 - 09:25 AM
My M3 came from the factory with Launch Control. Its good fun
Posted 10 November 2014 - 09:52 AM
OK, I'm going off a guess here...but is that a 998?
Posted 10 November 2014 - 01:28 PM
and about 20% wheel slip so it don't bog down.
Posted 10 November 2014 - 06:20 PM
Tis indeed. Why do you ask?OK, I'm going off a guess here...but is that a 998?
