Launch Control
#16
Posted 10 November 2014 - 07:26 PM
#17
Posted 10 November 2014 - 07:32 PM
#18
Posted 10 November 2014 - 07:43 PM
#19
Posted 10 November 2014 - 07:52 PM
#20
Posted 11 November 2014 - 11:44 AM
#21
Posted 11 November 2014 - 02:15 PM
I'm doing it just for the pops and bangs :L
this is the only reason i would do it haha
#22
Posted 11 November 2014 - 02:36 PM
Personal don't see the point but
a oo each to there own
#23
Posted 11 November 2014 - 10:49 PM
Test 2 (second test video'd anyway)
Got some new wiring and scrapped me quick react solid state relay that I waited for weeks for
#24
Posted 12 November 2014 - 02:08 AM
#25
Posted 12 November 2014 - 02:49 AM
Haaha classsss
Does it pop and bang a lot on the limiter?Or, does it say 5.....4......3......2......1..... Euston " IGNITION " we have lift off.....
Or Houston even!
#26
Posted 12 November 2014 - 11:52 AM
The MJ hard limiter doesn't just cut off the coil, if you did that you'd get a spark every time it operated. As that could happen anywhere in cycle it could be at piston destroying degrees of advance. Autosport's answer is to switch in more resistance with a mosfet, about 20ohms @ 10watts.
If you want to do your own thing
I like Nick's tactics:
The best solution would be to hack the MJ code to run the soft limiter off load or auxiliary inputs, wonder if Autosport have considered this? As a work around, you could set up a row of retarded advance bins on your map that are triggered when you push those inputs out of their usual range with a resistor that connects to one of them when you operate your launch switch.
#27
Posted 13 November 2014 - 08:43 AM
I need this.
#28
Posted 14 November 2014 - 07:07 PM
Haaha classsss
Or Houston even!
Depends where it takes off from..........
#29
Posted 29 November 2014 - 10:46 AM
