Engine Not Firing On Cylinders 1And 4
22 replies to this topic
#1 neilbut1988
neilbut1988
  • 22 posts
Posted 12 November 2014 - 07:57 PM
I have a 1275 a series engine with some starting and low rpm issues. At tickover the engine is only running n cylinders 2 and 3. Compression on all cylinders are good and valve clearances are set to 12tho. When the revs are increased the engine seems to run on all 4 but at tickover plug caps 1 and 4 can be removed with no change!?!?
#2 neilbut1988
neilbut1988
  • 22 posts
Posted 12 November 2014 - 07:59 PM
Plugs 1 and 4 are wet and the carb is a weber 40 dcoe.
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 12 November 2014 - 08:00 PM
Has this problem just started, or have you done anything which coincides with this?
Are the leads in the correct order?
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 12 November 2014 - 08:09 PM
Have you whipped a plug out and checked if it's sparking?
#5 neilbut1988
neilbut1988
  • 22 posts
Posted 12 November 2014 - 08:56 PM
I have a good spark on all 4 cylinders and the engine has just been full rebuilt. Its a 1275 with a stage 3 mini sport head, calver 13ot cam and 40 dcoe.
#6 neilbut1988
neilbut1988
  • 22 posts
Posted 12 November 2014 - 08:57 PM
And yes the leads are correct
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 November 2014 - 09:41 PM
Have you checked your inlet manifold is not drawing air ? wd40 around the flanges and check for any signs ?
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 12 November 2014 - 09:43 PM
Compression test would be worth doing.
#9 Spider
  • 15,007 posts
Posted 13 November 2014 - 12:53 AM
Sounds like the idle mixture has been set too rich.
#10 jaydee
jaydee
  • 8,565 posts
Posted 13 November 2014 - 09:50 AM
Seen it happening with long duration cams and weber carbs, its either a too low advance at idle or too rich mixture at idle
#11 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 13 November 2014 - 10:11 AM
Are you running a standard distributor or are you running Megajolt or similar?
#12 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 13 November 2014 - 10:16 AM
It does just sound like my old 1380 was when I first fitted the 45, though.
Idle mixture might just need a tweak.  Mine seemed to flood more on the outer two cylinders, possibly related to the siamese inlet ports and the way the fuel/air is drawn through the carb.  Probably exaggerated if you're running a 'swan neck' manifold too?
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 November 2014 - 12:40 PM
You said this is a freshly rebuilt engine.  The following is not meant to be derogatory so do not take it that way.  Are you SURE the plug wire order is correct?  It is very easy to put the distributor drive gear in a non-standard orientation during an engine rebuild.  It is also very easy to forget and put the plug wires on the cap in a clockwise vs counterclockwise order.
Though you are sure you have this right, take off the valve cover and make sure that when the timing pointer is at TDC, the rocker arms above cylinder #1 (water pump end) are "loose" and can be wiggled which indicates the valves are fully closed (#1 at TDC on its firing stroke).  If the dizzy drive gear is in the correct orientation, the distributor rotor will be pointing somewhere between 1:00 and 2:00 o'clock.  The spark plug lead for #1 goes there and the remaining wires go 1-3-4-2 counterclockwise around the cap when you are looking down on the top of the installed cap.
#14 neilbut1988
neilbut1988
  • 22 posts
Posted 13 November 2014 - 09:08 PM
Glad you have said that about the plug leads because I throught I had got it wrong so I have checked and I have it correct. With the engine running at 800 rpm it is running on cylinders 2 and 3. Pick the revs up to 1500 and you can hear 1 and 4 start to fire properly. I have tried adjusting the mixture screws (I wound them in until the it wouldnt run at all and backed them out until I got a good engine note) am I doing this correctly?? Would a new coil help?
#15 neilbut1988
neilbut1988
  • 22 posts
Posted 13 November 2014 - 09:09 PM
The car is running a 23D a series distributor.
