How advanced have you set the ignition timing at idle?
Engine Not Firing On Cylinders 1And 4
#16
Posted 13 November 2014 - 09:18 PM
#17
Posted 13 November 2014 - 09:30 PM
800rpm is far to low a idle take it up to 1000rpm and re-adjust the carb mixture and see what it runs like then
#18
Posted 13 November 2014 - 11:01 PM
#19
Posted 14 November 2014 - 07:31 AM
Tickover at 800rpm is definitely too low for your engine spec. I mean, they are all different and I'm not that familiar with your cam, not sure what your compression ratio is, but I'd guess 1000-1100rpm will give you a much smoother tickover.
#20
Posted 14 November 2014 - 05:26 PM
#21
Posted 14 November 2014 - 05:36 PM
For timing, as comparison I have a 1293 running milder cam than yours and this is about 12 deg static, about 18 deg at 800-1000rpm, and maximum total advance of 32deg all in by about 3,500rpm.
#22
Posted 14 November 2014 - 06:31 PM
You may not need so much advance static and 18degs at 800-1000rpm as carbon, depending what distributor you use, you could always try 32degs max advance at 5000rpm and see how you go from there, you may not need to rev that high depending on what springs your distributor has, so you may see by 4000 its all in and does not go any more. I use a Aldon yellow and 12degs at 1000rpm vac off.
#23
Posted 15 November 2014 - 08:49 PM
