To Sump Guard Or Not To Sump Guard?
Posted 23 November 2014 - 10:18 AM
I've got an innocenti guard and I'm not sure wether to fit it or sell it??
Posted 23 November 2014 - 10:33 AM
I like the look and had one kicking about and was tempted to fit it. Decided against it after reading about potential problems with cooling, and the need for an oil cooler to compensate. Also not really neccessary unless you're car is ridiculously low and the speedbumps particularly vicious where you live.
Posted 23 November 2014 - 10:55 AM
Posted 23 November 2014 - 11:00 AM
Posted 23 November 2014 - 11:16 AM
I have one in my room from my dads old MK1 mini that has lived on, recently did a little resto on it, just waiting for a sunny day to install it.
Posted 23 November 2014 - 08:08 PM
You do need an oil cooler with a normal sump guard. However, I believe the Innocenti-type is more of an open pattern so cooling may not be an issue.
Unless driving fast on seriously rough roads a sump guard should not be necessary on a road Mini.
Remember, you lose about 1" of ground clearance if you fit a guard.
Posted 30 November 2014 - 08:39 AM
I wouldn't bother fitting it (p.s sent you a Personal Message idlethumbs)
Posted 30 November 2014 - 10:55 AM
I have one fitted to my std.998 - it came with the car.
My mini runs well & running temperature is definitely not a problem. Without a specific OIL temp. gauge, should I remove, or keep 'as is' .?
I wouldn't' buy one, but as it came with it, just left it in situ.
Agree, have to remove for servicing, but it's only 5 bolts!
Posted 30 November 2014 - 04:13 PM
I wouldn't bother for everyday driving.
Posted 30 November 2014 - 06:46 PM
Never had a problem temperature wise with one fitted on a 998. Didnt have an oil cooler.
Liked the way you could easily jack it up directly on the sump guard, spreading the load to the subframe.
Posted 01 December 2014 - 08:07 AM
Our Mokes all came factory fitted with sump guards. For normal day to day driving, i don't bother with them, however, there is no way on earth I'd go away without it!
