Inner Wing Starter Solenoid Clicking
Best Answer frodmyster , 29 November 2014 - 10:25 PM
Turns out the starter is goosed. Tested off the car with a fully charged batter and nothing. All cruddy inside the starter and the copper coils are burnt beyond repair.new starter and solenoid ordered :):) thanks peeps Go to the full post
Posted 27 November 2014 - 11:56 AM
Posted 27 November 2014 - 01:56 PM
Posted 27 November 2014 - 02:02 PM
My money is on it being a stuck starter motor.
Posted 27 November 2014 - 04:46 PM
test the voltage with the solenoid in the start position, none is a faulty solenoid and follow the voltage to the starter, rock the car in gear to see if the starter bendix is stuck
Posted 28 November 2014 - 10:04 PM
Posted 29 November 2014 - 03:08 PM
Nothing? Short out the two main connections (out of gear!) does it turn the engine?
Use jump lead from battery direct to starter...if engine turns all points to solenoid fault....tenner from Minispares
Posted 29 November 2014 - 05:10 PM
Assuming you mean the solenoid continuously clicks if you hold the key in the start position?
That's symptomatic of the voltage taking a nose dive as soon as massive load of the starter is connected. All of the above are possibilities so it's a process of elimination...
Bridging the solenoid screw posts (out of gear) eliminates it from the circuit.
Jump leads and a known good battery can be used to home in on faults in the battery & earth cabling.
A big current and localised resistance in the circuit makes heat.
Stalled motors flow lots of current causing even more voltage drop.
Posted 29 November 2014 - 10:25 PM Best Answer
