If the the exhaust is sooty then lthe cat is easily plugged. I cleaned a plugged cat by blowing the soot out with air pressure. If the cat is cold you can also in addition fill it with gasoline and shake it hard, let it stay for an hour and shake again. Gasoline only kills the cat if the cat is hot and can react.
If you have a strong light you can see Honeycomb structures. If you do not see the structures then it seems heavily plugged. What happens is: The soot is still burning after you stop the engine.
In essence then you can throw away the cat because the platinum-rhodium catalytic layer is dead. This layer is the catalyzing element.
The worst thing is, if ignition causes little explosions into the exhaust. Then, the cat is definitely destroyed in its catalyzing function.
If your cooling system is free of blocking elements then I would change the coolant temp sensor, the oxygen sensor and the cat (--> next MOT !). Before you build in the lambda sensor you have you should measure it.
As far as I know from my 93 SPI, the SPI has NO MAP SENSOR. This one is only for the MPI.
Edited by Alpenflitzer, 07 December 2014 - 11:17 AM.
