Hi, i have a little 998 in good working order, but I want a bit more power. It has a standard block, and I was wondering what the maximum capacity it could be bored out to?
Posted 02 December 2014 - 04:24 PM
Posted 02 December 2014 - 05:04 PM
Mines out to +30, unsure if you can go higher.
Posted 02 December 2014 - 05:06 PM
You can go to +0.080" with absolutely no risk at all. That gives 1060 cc. But you won't gain much unless you fit a much improved cylinder head, fully gas flowed with a higher compression, together with a better cam, induction & exhaust system.
Posted 02 December 2014 - 07:07 PM
Posted 02 December 2014 - 08:13 PM
Pistons are available to take them out to +0.120" though you need to off-set bore them.
Posted 02 December 2014 - 09:49 PM
On a gas-flowed 12G295 head with larger inlet valves, a 3-into-1 ex. manifold, RC40 exhaust system, HS4 on alloy manifold, 510 cam accurately timed in, lightened flywheel, 10.3:1 CR, re-curved distributor, flat-top Hastings pistons, bored to 1060 cc I got 65 bhp at 6000 rpm. Torque was good too and with a 3.44:1 FDR it went well and was not quite so slow.
Posted 03 December 2014 - 01:36 AM
Posted 03 December 2014 - 04:58 PM
How much are those pistons?
Posted 03 December 2014 - 05:35 PM
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
