Hi there, recently my mini has been pretty much refusing to idle once up to temperature. I've cleaned the IACV, and although I have also heard the manifold gasket could be to blame - and ill check this- im pretty sure im going to have to replace the valve.
As everyone knows, they are quite difficult to find, and the only ones I can find seem to be ones from Rover 200s and the like, like this
The left half looks the same, but the right bit is completely different, although it does look like this might screw off and reveal the valve as per the mpi. Can anyone confirm this? And will it screw on as normal?
