Advantage Of Double Throttle Cables?
16 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 18 December 2014 - 06:22 PM
Hi peeps :)
My weber linkage kit came with a kit to convert my throttle pedal to accept 2 throttle cables ( comes with 2 throttle cables etc too).
But what the is the actual advantage? (except the looks of it :D )
I think I'll be using it, just because I need a new throttel cable anyway... :P
10393551_745560915512104_512885453066754
cheers
Edited by Dusky, 18 December 2014 - 06:23 PM.
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 18 December 2014 - 06:25 PM
Main reason would be if one breaks you can still drive the car, although as load spread between 2 cables less chance of breaking anyway
#3 Spider
  • 14,909 posts
Posted 18 December 2014 - 07:48 PM
Mmmm.... I have broken 1 or 2 cables over the years and I've caught probably as many before they went. I feel that having twins will only increase the friction, which may necessitate heavier springs, further increasing wear and foot fatigue. Just a thought, I've not tried them.
#4 Dusky
Dusky
  • 5,322 posts
Posted 18 December 2014 - 08:27 PM
It looks great though :D
I'm only worried about the blue block comming loose!
#5 nicklouse
  • 18,605 posts
Posted 18 December 2014 - 08:41 PM
The issue is mounting to the pedal.
#6 sledgehammer
sledgehammer
  • 3,098 posts
Posted 18 December 2014 - 08:52 PM
In the past , when a cable broke , I've driven home (approx 20 miles) on the heater cable
Definitely NOT recomended
I find when they go - they stick open - so not good
not sure wether 2 would be any more reliable than 1
keep em well oiled
#7 Dusky
Dusky
  • 5,322 posts
Posted 18 December 2014 - 10:06 PM
Mounting is no problem :P they come with an adaptor block :P will use it just because they supply it :P i tought more people would be using them :P
#8 Craig89
Craig89
  • 600 posts
Posted 18 December 2014 - 10:13 PM
You see them alot on rally cars, mk2 escorts and the like and they are just a back up incase 1 snaps
#9 Bubblebobble
Bubblebobble
  • 661 posts
Posted 18 December 2014 - 10:14 PM
Same as twin coils and fuel pumps .
#10 nicklouse
  • 18,605 posts
Posted 18 December 2014 - 10:20 PM
How does the block fit? So some pedal assy bending. Drilling new holes in the bulkhead and fitting retainers for the pure cable.
Have fun.
Just use one.
#11 Tupers
Tupers
  • 4,149 posts
Posted 18 December 2014 - 10:29 PM
Is that not the block they use to make one cable actuate to carbs?
Having two cables at the carb end is no good if the single cable at the pedal can still break.
#12 Mk1Dave
Mk1Dave
  • 519 posts
Posted 18 December 2014 - 10:58 PM
That's what I thought
Edited by Mk1Dave, 18 December 2014 - 10:59 PM.
#13 nicklouse
  • 18,605 posts
Posted 18 December 2014 - 11:01 PM
No that is the one that goes onto the pedal rid end where the single cable goes in/on.
http://www.demon-twe...le-linkage-kits
Edited by nicklouse, 18 December 2014 - 11:02 PM.
#14 Dusky
Dusky
  • 5,322 posts
Posted 18 December 2014 - 11:07 PM
Have fun.
Just use one.
No pedal bending etc,just a straight 'plug and play' assembly.
#15 mini13
mini13
  • 3,810 posts
Posted 19 December 2014 - 10:26 AM
two reasons for these,
1 reliability,
2 when a throttle cable goes on a rally stage, chances are it will be at full throttle, loosing power half way through a bend is often going to result in a smash from lift of oversteer.
