the bores and pistons may be fine and it might be the guides,valves or both in the head causing the problems.
Cylinder Compressions
#16
Posted 22 December 2014 - 03:37 PM
#17
Posted 22 December 2014 - 05:41 PM
Was the head and block deck checked for "flatness"?
#18
Posted 22 December 2014 - 06:01 PM
yours scratching head!!!!
#19
Posted 22 December 2014 - 06:02 PM
They are all a bit low generally, with the centre two especially so.
What was the compression ratio set to?
It won't be valve guides as they have no bearing on compression figures.
It might be rings not bedded in, or something more serious.
#20
Posted 22 December 2014 - 06:11 PM
Do another 200-250 miles and check the compression again-expect to see an equalisation across the cylinders and increase in psi (150-160) as well as reduction in visible oil smoke as the rings 'bed-in'.
Does the car only smoke when the car has been idling or when you accelerate after being on closed throttle/on overrun? This would indicate worn guides (oil being drawn down them) and has very little to do with low cylinder readings you have currently.
Go and run the car, short local loops so you aren't too far from home. If the motor goes off song or shows any sign of overheating, get the car off the road asap. Whip the head off and inspect the bores. A good quality hone will still show oil retention cross hatch all around the cylinder bore. If the head gasket was new when the engine was built I can't see how it would have failed between 2-3 with just sixty miles on the clock. Unless it was duffer (There was batch of suspect BK450's around 12-18months ago). Personally I'd use copper H/gasket but it again is down to preference.
Edited by fwdracer, 22 December 2014 - 06:12 PM.
#21
Posted 22 December 2014 - 06:30 PM
Thanks all
#22
Posted 31 January 2015 - 01:52 PM
Ive just stripped the head and im even more confused. Head gasket looks ok, but head and pistons have a tar like coating. Pictures attached. Ive out a steel rule across the block and head and appear flat.
Help!!!!!
Posted 31 January 2015 - 04:41 PM
Now you have the head off you can check all of the valve stems and guides for wear, and replace all the valve guide seals.
How many miles has this engine done since the build?
And are the traces of liquid in the piston dishes oil, or water from when the head was taken off?
#24
Posted 31 January 2015 - 07:36 PM
Since it was rebuilt it done about 500 miles.
Any thoughts?
#25
Posted 31 January 2015 - 08:10 PM
If the head is true then no need to skim. Do use a good quality gasket though.
#26
Posted 31 January 2015 - 08:58 PM
Ill keep you posted
#27
Posted 01 February 2015 - 07:04 PM
While you have the head off would suggest also do following :
- check and note type of piston fitted, find out piston dish capacity in cc
- check top of piston to block deck clearance, how far down the bore are they at tdc
- check depth of head, should be 2.75 inch unskimmed
- check head chamber volumes if possible.
With this info you should be able to work out static compression ratio of the motor.
#28
Posted 06 February 2015 - 07:45 PM
ive taken the measuresments, so how do I work out the compression ratio. Head chamber I dont know how to measure.
thanks
#29
Posted 15 February 2015 - 07:20 PM
Thanks in advance
