Think My Gearbox Is Broken, Someone Help!
Posted 29 December 2014 - 09:31 AM
Thanks in advance, Shane
Posted 29 December 2014 - 09:47 AM
I'd start by checking your engine steadies mate.
If the engine has moved you may not be able to select gears
Do you get drive in 4th ?
Posted 29 December 2014 - 10:05 AM
Posted 29 December 2014 - 10:19 AM
Posted 29 December 2014 - 10:29 AM
Check fluid. Sounds like an engine out whatever you decide is the problem.
Posted 29 December 2014 - 10:31 AM
Posted 29 December 2014 - 10:55 AM
Does it go into gear with the engine off?
Posted 29 December 2014 - 11:38 AM
Posted 29 December 2014 - 02:18 PM
any noise ?, if not the mainshaft nut has come off and so has the pinion....
Posted 29 December 2014 - 03:21 PM
Posted 29 December 2014 - 04:33 PM
one of your pot joints has not come out of the splines ?
Posted 29 December 2014 - 08:19 PM
Or a busted drive shaft, the one that nearly always goes is the RH one, on the outboard end
While on the ground, start it, put it in gear (with the brakes on!) and have someone look at the shafts, if one is turning, that'll be it.
The other thing it could be (associated with the engine movement) is a busted teeth from the Final Drive or a spit Planet Gear, but 99 times out of 100, the spilt sun gear with also get spat out the diff cap.
Edited by Moke Spider, 29 December 2014 - 08:25 PM.
Posted 29 December 2014 - 09:05 PM
Try it again but this time get someone to look into the engine bay and look if one of the drive shafts is spinning.
Posted 29 December 2014 - 09:16 PM
If this is the cause then speedo will still work but you won't get drive...
