Sounds like stuff that you definately don't want to confuse as shampoo!!!!
you definitely wouldn't, the vapours from it knock you for six, ten times worse on a hot day.
Posted 04 January 2015 - 06:24 PM
Posted 04 January 2015 - 09:37 PM
Is there anything a little less brutal and lethal that us everyday people can use to shift Powdercoat? I want to totally strip my wheels back to bare ally and paint them properly, but don't fancy stripping them manually....chemicals are far easier.
Posted 04 January 2015 - 11:51 PM
depends on the actual coating, for most stuff paramose will be ok, they do two, you want the one that isn't water washable. if they've got epoxy on them as a base then you will struggle as it just tends to thin the surface a tiny bit and you get literally a couple of microns off!!
Posted 05 January 2015 - 05:44 PM
Namby pamby paint stripper doesn't touch it (which you'd expect) but does soften the paint top layer. Then i tried some celulose thinners and that did soften the white powder coat.
Will have a look at the Paramose stuff
Posted 05 January 2015 - 09:54 PM
you might struggle to get hold of it, some places are a bit funny about even selling it, if you can't get any give me a shout, am only on the wirral so not far.
Posted 05 January 2015 - 10:14 PM
blasting doesn't get powdercoat off unless you go for high pressure and flow with ally oxide, ie industrial, even that struggles, also makes a mess of the surface.
Not true, I can get power coat off my parts at <100psi in my blasting cabinet with glass bead. It is however very slow, I'd hate to do 5 wheels! Doing a single wheel spacer when water got in my line took almost 2 hours.
Posted 05 January 2015 - 11:15 PM
syphon or pressure pot cabinet?
Posted 06 January 2015 - 01:23 PM
Posted 06 January 2015 - 05:42 PM
Posted 06 January 2015 - 11:31 PM
