On installing my wooden ash dashboard do i have to cut my air vents and fit with supplied air vent tubes?
How can i remove the full unit of the air vents on passenger side and drivers side?
Putting A Dashboard Into Place Do I Have To Remove The Air Vents?
willjones444
, Jan 04 2015 10:16 AM
2 replies to this topic
Posted 04 January 2015 - 10:16 AM
Posted 04 January 2015 - 11:37 AM
Generally you will need to remove the eye ball vents, then connect them to the dash and use the ducts supplied with your new dash to bridge the gap between the back of the vent and the hole in the flitch panel. To remove the vents unscrew and remove the large plastic retaining ring on the front of the vent, this should then let you remove the cone shaped plastic shroud behind, you then turn/rotate the eye ball vent slightly to disengage and remove it from the flitch panel.
Posted 13 January 2015 - 09:13 PM
Or do what I did, remove the eyeballs and put 4" speakers in instead..
