Took off the right-hand wiper stalk on my column switch arrangement and re-arranged it so that it worked from a Mk3 2speed switch on the dash. That left me with the left-hand switch for....horn/dip and indicators. These all work fine HOWEVER I stripped the plastic coating off the stalk itself as I wanted it to be polished alloy look and even made up a little beeper circuit that beeps when my indicators or hazards are on.......annoyingly good especially if your indicators won't self-cancel . HOWEVER I find that for some reason my polished alloy indicator stalk is .......LIVE........ even with the ignition off. HELP I know I should get out there in the cold and sort it by removing wires and/or fuses but has anyone got a quick solution??? before I freeze me bum off.
Edited by splintercat, 04 January 2015 - 03:20 PM.
