Rear Subframe Torques
16 replies to this topic
#16 F1L8EY
F1L8EY
  • 600 posts
Posted 14 January 2015 - 12:10 PM
Yes is is always stated weather to dry torque or wet torque as the before mentioned it affects the locknuts rundown as has been calculated as such. I wouldn't lube a Nyloc  unless i was lubing it with lock tight ;) HAHA
one step further it will normally state to clean certain critical components with alcohol of type to degrease and dry the threads. on top of this, again probably specific to aircraft... we have a lot of one use only bolts and nuts, it wouldn't be viable to do this in a hobby car environment but again it just ensures the correct torque is always being applied.
last bit, anything that you torque on the car, torque 3 times... have a cuppa... torque again and the nut shouldn't move not even a 10th of an inch... if it does back to step one.... if it passes another cup of tea and try again in another 10 minutes. I've had bolts that have been torqued this way and have lost torque over night when things move or sit, or the temperature drops. and things like the head on the engine need to be torqued in sequence to get the correct loading. follow it and check them again in 25-50 miles of driving just to be safe and sure :D
#17 Spider
  • 15,201 posts
Posted 14 January 2015 - 07:16 PM
Cheers :-)
According to some Loctite literature I read a few years back they claimed if the compound was kept in a fridge before use, it slowed it's reaction and could be used as a fastener lube. I've never checked if this is what does happen, but it does have to be better then going dry.
Alcohol isn't a good idea in my workshop :D :D :D   I actually use multipurpose paint thinners (best chilled to 2 degrees before adding the Orange Juice ;D ) for cleaning various critical parts, including threads, before assembly, but if a Nyloc is to be fitted, I leave it for a good 15 minutes before fitting the Nut, just in case the Thinners reacts with the Nylon (which it shouldn't).
There is some VERY good info over on the ARP Website on fasteners and 'Torquing' them, in particular regarding the lubricating of fasteners
http://arp-bolts.com/p/technical.php
