Recommend Amp And Subs
57 replies to this topic
#46 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 26 February 2015 - 03:02 PM
So your running all 4 of the JL subs?
how do you plan to wire them to the Ultra two ?
#47 Richie83
Richie83
  • 1,494 posts
Posted 26 February 2015 - 06:28 PM
Gordon has recommended I run two subs per channel in parralel.
#48 Richie83
Richie83
  • 1,494 posts
Posted 26 February 2015 - 06:33 PM
Don't use Silicone sealant, the fumes it gives off as it cures will eat in ot the rubber used in the speakers! Use a polypropylene sealant.
Good to know. I actually bought caulk, thought that would do it?
#49 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 27 February 2015 - 09:46 AM
This i what i was going to say. So your going to be running stereo subs (two each side)? or do you plan to mono the signal??
If you're running stereo subs then you must make the enclosures separate, as each side will be doing slightly different things.
#50 Richie83
Richie83
  • 1,494 posts
Posted 09 March 2015 - 08:09 AM
Spoke to Gordon and he said it won't be an issue as each side will be mono. Began the build this weekend by bolting in some metal angle and drilling the lip for my double thickness baffle. I also sealed and deadened the whole area.
2DB72C15-E80D-420C-B274-84B6083CEEAC_zps
The baffle is very tight with the carpet on. I am going to add draft excluding tape on the metal angle and edges. This will squash down to make it more air tight:
BA8A47EC-7D61-450A-AC70-5C5BBFBEB360_zps
Edited by Richie83, 09 March 2015 - 08:12 AM.
#51 Richie83
Richie83
  • 1,494 posts
Posted 18 March 2015 - 09:33 PM
So my Genesis P2 ultra is here and Gordon added LP filters to my P4 to go active. I now realise I may not need to use the Amps crossovers, but can if I want. Question is should i use the PRS-80 crossovers or the amps crossovers to go active?
#52 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 18 March 2015 - 10:45 PM
Use the headunit if it gives you enough control.
It will be easier to tweak going forward, taking a tiny screwdriver to the amp adjusters every time you want to make a little change or just to hear what it sounds like will be a pain.
Plus you will be able to have SQ and more streetbass setting all from the headunit...
#53 Richie83
Richie83
  • 1,494 posts
Posted 19 March 2015 - 06:53 AM
Okay. I'll give it a go. Going to run an inline fuse for the tweets just in case when setting up.
#54 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 19 March 2015 - 08:54 AM
? never heard of that... but wont hurt.
#55 Richie83
Richie83
  • 1,494 posts
Posted 09 April 2015 - 05:30 PM
Okay. A few updates for those interested:
I made up a double thickness baffle and routed out the holes. Then covered in acoustic carpet and marked out the screw holes with a soldering iron:
04068A36-7524-4A7F-B9B3-782407389E7B_zps
Decided to use sliver hex bolts for a nice contrast:
7630ADF9-6073-4B95-AE57-494F38F8A3DA_zps
I then cut my cable, crimped it up and put it in some braiding:
311EC418-CE06-43D2-A537-D5E1196808E6_zps
I then added draft excluder tape on all the edges and bolted it in the car (used 6 along the top alone as it weighs almost 2 stone):
BA8506A9-953E-448D-AC07-67FAD1CEEE5A_zps
They're wired up two subs to each channel in parrelel to an upgraded Genesis Profile 2 ultra. I've got my HU set to run in mono so they all kick at the same time.
Edited by Richie83, 09 April 2015 - 05:34 PM.
#56 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 09 April 2015 - 05:31 PM
Awesome install
#57 Richie83
Richie83
  • 1,494 posts
Posted 09 April 2015 - 05:37 PM
Awesome install
Thanks. Tempted to pop a thread up in ICE build forum, but feel self conscious as an amateur learning on the fly 😄.
#58 Miniac86
Miniac86
  • 334 posts
  • Local Club: MOCKZN
Posted 10 April 2015 - 11:06 AM
That looks awesome, try get a vid of them running and upload it to photobucket as well and definitely do a sound build thread in the appropriate section, it'll be great.
