Hello all,
I have a Mini MPI from 1998 (Monza Edition) and since two month i'm facing what it seems ECU problem. Full throttle
won't reach more than 2.000 rpm as you can see on the video.
I already change:
- Ignition coil pack - MPI
- Spark plugs
- New plugs
The mechanic already made a reset to the ECU and nothing happen.. then, we grab a Rover ECU and made a copy and start working perfectly...! But.... the next day returned to the same problem...
Anyone can give some tips what exactly is?
Edited by Diogo Tomaz, 17 January 2015 - 06:05 PM.
