I have a 998 engine and i was wondering if the performance would be much different if i put twin 1.5 su carb instead of a single 1.5 su carb
30 replies to this topic
#1 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2006 - 08:25 AM
I have a 998 engine and i was wondering if the performance would be much different if i put twin 1.5 su carb instead of a single 1.5 su carb.
Hi i have a standard 998 engine and i am going to change the carb and i was wondering if a 1.5 twin su carb would perform better than a 1.5 single su carb.
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 12 July 2006 - 08:32 AM
twin 1.5's will drown it.
twin1.25's will give it much better drivability
#3 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2006 - 08:39 AM
ok so what would be better a single 1.5 su carb or a twin 1.25 carb
#4 miniboo
miniboo
  • 9,327 posts
Posted 12 July 2006 - 08:43 AM
twin 1.25's personally
#5 minislapper
minislapper
  • 1,957 posts
Posted 12 July 2006 - 08:48 AM
I'm sure there was a discussion about this recently. Try doing a search and seeing what comes up.
Asking which carb is best is irrelevant in terms of performance etc as there are many factors which influence this. Just changing the carb will not make a difference for the better.
What the car will be used for is one consideration. Is it going to be a daily driver, track car etc etc.
The condition of what you have already is a major factor, ie trying to tune a tired engine is just throwing money away.
A different carb needs to be thought about in relation to other components too, ie manifolds/exhausts to name but a few.
Have a read of some of the previous discussions about tuning etc. There have been some good points made in the past. :-
#6 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Ok thanks for the advice, but would there be much of a difference between the two carbs.( single 1.5 or twin 1.25)
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
all depends what the carbs bolted to.... if it's a std 998 then I'd stick with the single...
If you had head work, bottom end changes, new cam etc etc then yes potentially the twins will improve matters.
#8 minislapper
minislapper
  • 1,957 posts
Posted 12 July 2006 - 08:50 AM
Carb discussion
#9 *DJH*
*DJH*
  • 4,972 posts
Posted 12 July 2006 - 10:54 AM
I Aggree With GuessWorks, Twin SU Setup Will Seriously Hamper The Performance, Not Imporve It. Since I Race A 1000cc Mini A Single Su 1.5" Is Much Better. With The Correct Setup Mine Out Accelerates A 1275 - 1310 With A Webber DCOE 40/45!
#10 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 12 July 2006 - 10:59 AM
Any chance of sharing this setup ! :-
#11 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2006 - 11:05 AM
Ok thanks what is the best thing i can do to gain performance.
#12 *DJH*
*DJH*
  • 4,972 posts
Posted 12 July 2006 - 11:11 AM
Yeah I'll Have To Dig The Paper Work Out From The Garage.
I Know That To Acheive This You Need A Different Needle, Spring And Air Filter. The Timing And Air - Fuel Ratio Has To Be Changed.
(So Basically The Car Runs Like Sh#t At Low Revs And Uses Copious Amounts Of Fuel, But Flies At High Revs)
#13 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2006 - 11:14 AM
Is there anything else i can buy to gain the performance. what would do the biggers change to the performance. at the moment i have stangerd everything
#14 miniboo
miniboo
  • 9,327 posts
Posted 12 July 2006 - 11:20 AM
Have just noticed that you have a city e which will mean it has a 2.95 diff.
best thing to make it nippier is give it a good service and then maybe looking at gearing a different diff.
this will improve you wacceleration but lower the top end speed. will make it a bit noisier and higher revving on the motorway tho
#15 *DJH*
*DJH*
  • 4,972 posts
Posted 12 July 2006 - 11:24 AM
Well The Common Way People Add Performance Is;
Stage 1/2/3/4 Kits
Some Other Ways (Expensive) Are;
Lightened Panels / Weight Removal.
Lightened Flywheel / Clutch Plates.
A Good LSD (Limited Slip Diff)
Straight Cut Gears (So You Can Have An Efficent Way Of Laying The Power Down)
Improved Air Flow / Induction.
Hose Upgrade (So They Can Hack The Abuse)
Serious Engine Engineering Mods.
Flow The Head / Port Polish.
GuessWorks Might Agree With Me On This, That Most Torque Is More Important Than Horsepower For Minis.
