Hi All
Hope someone can help me.
Recent work:
New clutch kit installed
Exhaust was blowing this was fixed.
Engine was running ok before work done.
Symptoms:
RPM goes up when the clutch is depressed.
Car refuses to idle below 1500 rpm
When driving car runs at about 2000rpm
When running without choke rpm drops and engine cuts out.
Before a carb retune idle would sometimes go from 2000rpm down to 200rpm then recover back up.
Things i have tried:
Replaced Spark plugs. no change.
Tried re-tuning carb still wont allow me to drop revs below 1500rpm without spluttering.
Needle in carb piston feels like it is on a spring is this normal?
I have checked the vacum advance pipe and also checked dizzy that the base plate moves.
Things done before clutch installed:
New leads, New rotor arm, new condensor. New dizzy cap.
Car: 1989 998cc with HS4 with waxstat jet.
