Try changing points and condensor
Get the CO (exhaust emissions) checked/ set to 3.0% at idle
Lumpy At Low Rrpm, Rpm Increases When Clutch Depressed.
dphx42
, Jan 23 2015 09:39 AM
17 replies to this topic
#16
Posted 13 February 2015 - 06:01 PM
#17
Posted 13 February 2015 - 11:17 PM
Update:
Ive now replaced the manifold gasket and the manifold nuts.
Ran a compression test : Cyl 1 (155psi) Cyl 2(155psi) Cyl 3(165psi) Cyl 4(155psi)
No whistle but still having a lumpy / mild kangaroo at low speeds.
Only things ive not done are contacts & timing (i dont have a timing gun yet!)
Mine was kangerouing alot at low speeds, lighter dashpot oul (atf) sorted it.
#18
Posted 16 February 2015 - 03:30 PM
I'll get the contacts changed. Ive had a new condensor.
Also could it be the ignition coil?
I currently have 10w40 in the dashpot.
