Lights
Best Answer hellom8 , 26 January 2015 - 08:51 AM
I had issues with the lights not coming on and then when they did, if I used the flasher everything would go off again.
One by one I pulled the bullet connectors apart and cleaned them with IPA and now it's fine.
Go to the full post#1
Posted 25 January 2015 - 07:24 PM
Posted 25 January 2015 - 10:24 PM
need a bit more info? Is this a resto and just connecting the wiring or have you done any other electrical work, or is this a later car thats still got the dim dip circuit fitted?
Posted 25 January 2015 - 10:53 PM
Posted 25 January 2015 - 11:43 PM
On the Headlights you only have 3 wires
Blue/red - Dip beam
Blue/white - Main beam
Black - Earth
If thats all you have done is reconnected the lights then you may have some sort of earth issue going on, if they all worked before and after just reconnecting the bullets you have this issue time to revisit those bullets
Posted 26 January 2015 - 08:51 AM Best Answer
Posted 26 January 2015 - 09:05 AM
Posted 26 January 2015 - 09:26 PM
Headlights 3 and 1 sidelight, I didn't mention the sidelight wire as the OP said it was confined to the headlights
