Hi,
Recently my Mini has been a pain to drive in the rain, as the distributor gets wet. I've heard you can get a sort of 'Sock' to cover it.
Where can I get these, and what are they like?
Thanks,
Corey.
Best Answer Corey96Williams , 28 January 2015 - 05:30 PM
You want to get a splash guard for your mini. Cheap and easy to fit. Plenty on ebay.
will be worth fitting electronic ignition too, puts up with more stick.
Agreed. Search for Weathershield.
I used to use a rubber glove and then upgraded to spray on ignition sealer years ago.
I've seen lots of posts on here saying weather shields are good, so I would go that route first.
If you have points, then changing to electronic at some point might save you some hassle.
I've already made a weather shield, but that obviously isn't quite enough. I've just put a rubber glove on over it whilst I had the chance.
If it continues then yes, I'll buy a proper splash shield
Go to the full postPosted 28 January 2015 - 04:07 PM
Hi,
Thanks,
Corey.
Posted 28 January 2015 - 04:11 PM
Posted 28 January 2015 - 04:25 PM
Posted 28 January 2015 - 04:48 PM
Posted 28 January 2015 - 05:30 PM Best Answer
