Bulkhead Access Hole Panel
17 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 09 February 2015 - 05:19 PM
I fabricated a cover for my Mk lll bulkhead access hole.  Can  anyone provide a specification for the necessary wiring and cable drive holes I need to make in the cover?
#2 evemark4
evemark4
  • 77 posts
Posted 09 February 2015 - 06:14 PM
Bottom left ( as u look at your pic )
That's were the standard hole is
For wiring / speedo
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 February 2015 - 06:28 PM
I don't think you would need any holes in it if it centre binnacle.
IIRC they are just left open from the factory just so you can access the bulbs without having to take the binnacle out.
If it's off set clocks, then you only have a large hole for the wiring loom to pass through
Ben
#4 newenglandmini
newenglandmini
  • 646 posts
Posted 09 February 2015 - 07:05 PM
My car is center binnacle.  I'm installing the cover to reduce the cabin noise level.
What is the size of the wiring/cable hole?
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 February 2015 - 07:06 PM
I don't think you need it as it's centre binnacle.
As i said, I think it's only left open to give access to the bulbs in the back of the binnacle.
#6 Coxie
Coxie
  • 461 posts
Posted 09 February 2015 - 08:55 PM
With the plate being flat, are you sure that your air filter will fit in once the engine is in.
I know my hif6 with cone filter sticks slightly into the recessed bit on my bulkhead plate.
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 February 2015 - 09:09 PM
good point there
#8 newenglandmini
newenglandmini
  • 646 posts
Posted 09 February 2015 - 10:22 PM
No, I don't know if there will be a clearance problem.  My car is disassembled to the part level, so I'll have to wait until I have the engine installed to check.  If necessary, I can modify my cover to provide any required additional clearance.
Ben, I know that the center binnacle design has various seals around the binnacle and gauges to reduce noise and prevent fume ingress.  It seems like a poor design, and I will be installing insulation on the bulkhead, which requires the cover for complete coverage.
#9 SMP
SMP
  • 346 posts
Posted 11 February 2015 - 09:05 PM
My sky had offset clocks and a removable blanking plate over the centre hole. When I changed to centre binnacle I retained the blanking plate and just drilled hole for speedo cable. The blanking plate is contoured and gives a nice finish. Can't you get a proper blanking plate from a later mini ?
#10 newenglandmini
newenglandmini
  • 646 posts
Posted 11 February 2015 - 10:17 PM
Is the blanking plate contoured to allow air cleaner housing clearance?  I have no source of used Mini parts here in the US.  I am envious of the plentiful supply (and low prices) of Mini's in the UK.  Is there a source of used bits willing to ship to the US?
#11 SMP
SMP
  • 346 posts
Posted 12 February 2015 - 07:16 PM
Yes the contours are there to clear the air filter. I've got a hif44 fitted with one of the big black donut filter housings fitted. Obviously I already had the plate because I was just changing the clocks. There seem to be plenty of people on this forum breaking minis ( mixed feelings about that myself) so one might be worth contacting. However my main point was that you can definitely have a blanking plate and centre binnacle. Perhaps you could dish the plate you've got or better still make an oversize plate - dish it then trim to fit. Cheers Steve
#12 Coxie
Coxie
  • 461 posts
Posted 13 February 2015 - 12:04 AM
Here's the plate on mine.
It has a pressed in section for the filter.
I have fitted a centre speedo and had to drill a hole through the plate at the bottom of the contoured bit so the speedo cable fits.Attached File  image.jpg   53.34K   33 downloads
#13 newenglandmini
newenglandmini
  • 646 posts
Posted 13 February 2015 - 01:04 AM
Thanks to all for your assistance.  I found a source on TMF willing to ship to me in the US.  Job done!
#14 newenglandmini
newenglandmini
  • 646 posts
Posted 28 February 2015 - 10:23 PM
I have received my panel cover.  What is the installation orientation; i.e., is the wiring loom hole at the top or is at the bottom?  I assume that it must align with the rear if the speedo, but with my car in bits I don't know where that is!
Attached File  PICT0029.JPG   42.97K   2 downloads
#15 newenglandmini
newenglandmini
  • 646 posts
Posted 01 March 2015 - 08:15 PM
Bump
