1360 Engine
19 replies to this topic
#1 G4RZZ
G4RZZ
  • 61 posts
Posted 13 February 2015 - 06:09 PM
How much bhp would you expect from a 1360 stage2,i have a chance of getting one cheap.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 13 February 2015 - 06:14 PM
Not sure what piston size you would need to get 1360.
#3 GraemeC
GraemeC
  • 7,438 posts
Posted 13 February 2015 - 06:19 PM
73mm
#4 GraemeC
GraemeC
  • 7,438 posts
Posted 13 February 2015 - 06:20 PM
There are so many variables to what power you'd get. Anything from 80 to 120 bhp!
#5 G4RZZ
G4RZZ
  • 61 posts
Posted 13 February 2015 - 06:33 PM
Id better upgrade my drum brakes then lol
#6 minilee94
minilee94
  • 3,523 posts
Posted 13 February 2015 - 06:42 PM
All depends on what other bits it has in the engine
#7 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 13 February 2015 - 07:57 PM
How long is the piece of string?
Seriously though bud, thats an almost impossible question to answer without knowing more about the actual engine spec.
Get some more details, and we can provide a more accurate guesstimation.
#8 G4RZZ
G4RZZ
  • 61 posts
Posted 13 February 2015 - 09:07 PM
I will be meeting the guy on monday so will ask for more info then thanks for the replies
#9 Cooperman
  • 23,293 posts
Posted 13 February 2015 - 09:44 PM
If it has a 73 mm bore make absolutely sure the bores have been offset or the head gasket will keep on blowing between 2 & 3.
Should that not be the case or if you can't be sure, then don't get it.
#10 G4RZZ
G4RZZ
  • 61 posts
Posted 13 February 2015 - 10:04 PM
I take it if it wasnt offset when board out it cant be done again
#11 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 13 February 2015 - 10:16 PM
Right. :)
#12 Cooperman
  • 23,293 posts
Posted 13 February 2015 - 10:24 PM
If it has not been offset bored, you could sleeve it back to 1275 and it would be fine again, but that would not be cheap.
The problem with buying big-bored engines which have been taken out to near the limit is that if/when another re-bore is needed it will be very expensive.
Unless racing a bigger engine is not an advantage really.
#13 GraemeC
GraemeC
  • 7,438 posts
Posted 14 February 2015 - 08:19 AM
At 73 you could still go out to 73.5 if offset bored. And then you can still sleeve back down again afterwards.
Although, despite Internet claims, there is no real shortage of blocks yet so I'd just stockpile one or two for future use with the bigger pistons.
#14 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 14 February 2015 - 08:21 AM
73mm doesnt need to be offset bored.
I have a 1360 engine, after my previous engine died, I needed a re-bore and as the engine hadnt previously been offset bored to accomidate 73.5mm pistons to go up a size to 1380, Southam mini metro centre suggested I look towards 73mm pistons to keep life in the engine. I did so and engine was still going strong till the shell rebuild
#15 GraemeC
GraemeC
  • 7,438 posts
Posted 14 February 2015 - 09:02 AM
No, it doesn't need to be. But if it isn't, i think it stops you going any further.
