I have seen a few adjustable ones online. I guess you drill and tap out the hex nut, but what size ? I was thinking UNF not metric, finer pitch better at sealing and you get more threads in the nut.
The thing is that, the online photos don't show you if there is some sort of spacer/washer that goes inbetween the the adjuster bolt and the spring. Most of the bolts that would be the same size as the flat on the outside would appear to be smaller than the inside diameter of the spring, so this would not alter the length of the spring. All the photo online only show the outside view
Any photo, solution iders greatly received.
PS it's a new race engine running about 90 lbs.
