Sintered Rockers - Pressed Steel Rockers
22 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 19 February 2015 - 04:23 PM
my mate has just put some of the 1275 pressed steel rockers on his mpi
to see if he notices any difference
and he reckons he notices a slight difference in performance
seems to open another 2mm
any comments
#2 Cooperman
  • 23,313 posts
Posted 19 February 2015 - 04:40 PM
Very doubtful there will be any noticeable difference on a road car. It's all in the mind ;D .
#3 racingbob
racingbob
  • 3,061 posts
Posted 19 February 2015 - 05:12 PM
he has got a modified head and maniflow
#4 Cooperman
  • 23,313 posts
Posted 19 February 2015 - 05:16 PM
Still won't make much, if any, difference. Even 1.5:1 roller tip rockers only give around 2 bhp extra and that is at very high revs with no gain below around 5500 rpm.
#5 Spider
  • 15,021 posts
Posted 19 February 2015 - 07:06 PM
If the valves are opening another 2 mm, then yeah, you would notice a difference.
Rather surprising though that there's that much variation between Pressed and Sintered types. I've not checked the Sintered ones to see what the true ratio of them is.
#6 racingbob
racingbob
  • 3,061 posts
Posted 19 February 2015 - 07:18 PM
Chris he said sintered was 40mm and pressed 42mm when measuring them on the head
so I assume 2mm more open, he took it for a spin after by himself
and came back and was sure it had more poke
#7 Cooperman
  • 23,313 posts
Posted 19 February 2015 - 08:09 PM
I was really surprised at how little measured difference going from sintered 1.3:1-ish to 1.5:1 R-R's made. It put the bhp up by 2 bhp at 5700 and over, whilst losing a bit at the bottom end. We didn't have time to measure the torque change, but I reckon I lost a bit low down.
I make the actual increased lift between 1.25:1 & 1.3:1 to be around 12 thou (0.012") = 0.3 mm. Going from 1.25:1 to 1.5:1 will give an increase in maximum lift of .060" which is 1.5 mm.
Can't see where a gain of 2 mm came from unless he has fitted 1.7:1 ratio rockers.
#8 racingbob
racingbob
  • 3,061 posts
Posted 19 February 2015 - 08:49 PM
I don't know weren't 1.7 just the ordinary early pressed
he said was definitely 2mm total difference
I will have to take it for a drive see how it goes
have driven it before, he said it pulled better
#9 Cooperman
  • 23,313 posts
Posted 19 February 2015 - 09:03 PM
The original were the presses steel type which were stated as 1.3:1. The sintered ones are claimed to also be 1.3:1 but experience has shown them to be around 1.25:1.
You can buy a 1.5:1 roller-tip version, but they are expensive for what you gain. The 1.7:1 are not widely used, except in racing as they tend to cause more rapid cam lobe wear, for obvious reasons.
It sounds as though the measurement of an additional 2 mm is incorrect if it is a case of swapping standard sintered rockers for early presses type.
Take the valve lift as 0.300" and do the maths. 0.3/1.25 x 1.3 = 0.312", so an increase in lift of 0.012" (= 0.3 mm). Maybe he measured 0.2 mm not 2 mm.
The performance gain when going from sintered to pressed types is the reduced inertia of the pressed type, especially when using very high revs. There will be no noticeable gain by lifting the valves an extra 0.012" at full lift.
#10 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 19 February 2015 - 09:09 PM
maybe the perceived performance gain is due to the recent setting of the valve clearances when the rockers were changed, so its basically running a bit better?
just a thought
#11 nicklouse
  • 18,654 posts
Posted 19 February 2015 - 09:12 PM
I feel someone is useing a special means to measure things.
I could never ever feel any difference between sintered.pressed or forged.
Now one set might have a very worn pad?
And did they not do some offset bushed kits in the 80s or some such.
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 February 2015 - 11:00 PM
Maybe his original sintered rockers were worn out.
#13 racingbob
racingbob
  • 3,061 posts
Posted 20 February 2015 - 09:40 AM
both sets of rockers are in good nik
will have to find out more about this
he set tappets to 12 same as before
#14 nicklouse
  • 18,654 posts
Posted 20 February 2015 - 09:45 AM
some reading.
http://www.calverst...._compendium.htm
#15 Dusky
Dusky
  • 5,322 posts
Posted 20 February 2015 - 10:46 AM
Maybe the difference is because of the modern manifacturing tolerances? EG: previous 'old' rockers were all like 1.25, 1.23,1.26,...
WHile the new are all 1.3? Could give  a VERY slight better 'balance'? ( just a thought, don't know if this is true)
