Remember to run a bead of weld accross the top of the pressed steel rockers, essential if you're running uprated springs and using high revs
Sintered Rockers - Pressed Steel Rockers
#16
Posted 20 February 2015 - 10:49 AM
#17
Posted 20 February 2015 - 11:23 AM
These rockers were probably fitted with offset bushing to alter ratio
I cant believe you got 2mm increase with them, its impossible the rocker arm would be too long for that
#18
Posted 20 February 2015 - 06:43 PM
One cannot argue with the engineering mathematics.
It is impossible to gain 2 mm additional lift by changing from 1.25:1 to 1.3:1 ratio rockers.
You would need to go from 1.25:1 to 1.7:1 to gain that amount, and it's unlikely that this has been done here.
Mis-measurement most likely.
#19
Posted 20 February 2015 - 06:53 PM
If the OP's mate prefers the pressed steel rockers then stick with it. The difference could be due to a number of factors so if it ain't broke don't fix it.
#20
Posted 20 February 2015 - 07:11 PM
Another factor to take in to consideration when swapping Rockers is the Rocker Tip Shape, just as the Cam has a profife to give quick or slow opening, the shape of the Rocker Tip aslo does the same, albiet, to a much lesser degree.
While I haven't profile checked them, sitting here thinking about the shape of these two Rockers, the Sintered version is 'flatter' than the pressed in tip of the Pressed Rockers, this will give an accellerated opening and maybe even more opening (when using Sintered Rockers).
So, if one was to graph the actualy valve opening on each set of Rockers, they would be quite different.
This can, of course have all manner of effects, and it could well be that one type works better with a particular Cam Profile / Cylinder Head over the next.
As most Cams only have between 6 to 8 mm lift, 2 mm increase while not sounding like much, is HUGE in percentage terms.
#21
Posted 22 February 2015 - 02:01 PM
I would imagine my mate has measured it wrong more than likely
don't realy know how he done it but would have only been aprox
#22
Posted 22 February 2015 - 02:05 PM
Chris he said 40 mm to 42mm which is what 5% but don't know how he did it I know he only used a tape
measure
#23
Posted 22 February 2015 - 09:02 PM
measure
Jeee sorry mate, I'm not familar with that type of dial gauge. Got a pic?
