What Grinder Discs
14 replies to this topic
#1 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 08:05 AM
Im back from holdiday and am going to get slme supplies needed to know what grinder discs to get thanks
#2 One step at a time
One step at a time
  • 282 posts
Posted 28 February 2015 - 09:11 AM
Thin ones for cutting 1mm thick.
To smooth down welds ect use normal grinding discs or flappy one, I'll find s link for these as I'm not sure what there proper name.
Edit.
Just checked and there called flap discs.
Edited by One step at a time, 28 February 2015 - 09:12 AM.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 28 February 2015 - 09:19 AM
As above 1mm for cutting. Try and get the thinner grinding discs (sometimes thick cutting discs) as these are easier to control than the thick ones.
#4 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 28 February 2015 - 09:31 AM
Like above, I was using 1mm to slitting/cutting. It avoids wasting too much material if you have to butt weld them together.
I was using 3mm disks to grind for more accurate grinding- such as lopping the top off welds (even though some places list 3mm as a cutting disk) Some times the disks dont last too long when the fiberious binding strands become visible.
I used 6mm disks for removing bigger chunks of weld etc, going down to 3mm to ensure I didnt attack the surrounding panels.
I used flap disks for finishing, smoothing the weld over.
Also I use a black and decker power file for where access is tight, its easier than a file!
#5 castafiore
castafiore
  • 116 posts
Posted 28 February 2015 - 10:18 AM
The thin power files are excellent. The B and D ones are about £40, though Aldi occasionally do them for £30. Good for final dressing down of welds or rust removal in tight places. Get the belts from eBay.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 28 February 2015 - 10:30 AM
I use something like these for all cutting
http://www.ebay.co.u...=item418ffb45ee
And these for grinding welds flat
http://www.ebay.co.u...=item35cd7e676e
And theses for heavier weldshttp://www.ebay.co.u...=item58a771a43c
Personally getting into tight corners I use a high speed air die grinder with carbide burrs.
Anymore info look at this pinned thread
http://www.theminifo...se-for-welding/
#7 midridge2
midridge2
  • 1,794 posts
Posted 28 February 2015 - 11:04 AM
P36 grinding discs are fine for all round use.
#8 Bubblebobble
Bubblebobble
  • 661 posts
Posted 28 February 2015 - 11:14 AM
I have always found it to be good sense to buy a good make of consumable . I have had cheap flap discs that have the flaps glued on with a big splodge of glue in one area , meaning they vibrate really badly  and wear out quick . I have used 3M stuff and some other make which i cant remember for 1mm discs , something like Klingspoor .
 I prefer flap wheels to a hard grinding disc as most people gouge great lumps ot of things with solid discs , and they are bloody noisy !
#9 Stu.
Stu.
  • 912 posts
Posted 28 February 2015 - 01:26 PM
I got some really cheap 60 & 80 grit flap wheels from Poundstretcher a few months ago. I thought they'd be rubbish but they're actually very good, cut well and dont wear too quickly.
#10 Cooperman
  • 23,326 posts
Don't forget a good quality pair of ear defenders and strong goggles.
#11 mini93
mini93
  • 8,615 posts
Posted 28 February 2015 - 06:54 PM
Just to re-enforce that... goggles, not safety glasses. and ensure they fit well!
I was using poor fitting goggles and managed to take a fleck of metal to the eye after it bypassed the seal up against my nose. Trip to hospital and a needle stuck in the eye to retrieve the foregn object and away I went.
New goggles were bought before stepping foot back into the garage!
#12 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 28 February 2015 - 07:19 PM
I wouldn't risk the cheap one's from places like pound shops personally. I've had more than one budget brand disc disintegrate whilst in use, sending sharp broken shards of disc flying in all directions. Trust me, even if you're wearing decent safety goggles, the last thing you want is something spinning at 10,000 rpm to start disintegrating inches from your face!
Screwfix sell quality branded discs at really quite competitive prices, so for a couple of extra quid it's really not worth sacrificing your safety.
#13 Bubblebobble
Bubblebobble
  • 661 posts
Posted 28 February 2015 - 07:21 PM
I am a baby and wear slim goggles and a face visor . Ive had many discs explode when some idiot has put pressure on it sideways - cue bits in your face .
#14 mingy
mingy
  • 930 posts
Posted 28 February 2015 - 07:50 PM
Use the cutting and grinding discs manufactured by " Klingspor ", the best quality products around and the technical help is first class.
#15 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 01 March 2015 - 01:27 PM
I cant recommend uvex safety goggles enough! Seal well around your eyes, vetiliated and very comfortable. Can pick them up on ebay for less than £10 well worth every penny! Trust me.
