Inner Wing
25 replies to this topic
#1 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 12:18 PM
Hi how do i remove the front part of the inner wings ill show some pics to make more sense of it
http://postimg.org/image/nona77g4h/
http://postimg.org/image/4xlcx1lk1/
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 28 February 2015 - 12:23 PM
The whole wing is spot welded in place so you need to find all of these to remove them. Have a look at the Project Erm link in my signature and you will see what and where you need drill, remove etc.
#3 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 12:31 PM
I dunno how to find that im using an iphone for the forum
#4 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 01:01 PM
Could i just grind it off
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 28 February 2015 - 01:02 PM
Chop the majoritie off, then as above drill out the spot welds where it's attached to.
#6 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 01:14 PM
http://postimg.org/image/toxlbtuw7/
So the gring up the middle were that bracket is
#7 alex-95
alex-95
  • 6,042 posts
Posted 28 February 2015 - 01:20 PM
Cut just in front of it so you don't damage it, then you can see the spot welds which you can drill out and remove the rest of the wing.
#8 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 28 February 2015 - 01:55 PM
what you need to get to is this
This what you start with
This is where i cut down so just forward of the gusset mount
Here i removed the gusset due to rust
New reinforcing plate welded to the end of the cross member. Make usre you fit one, mine is made from 1.2mm steel sheet.
New inner wing in place
welded in place
#9 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 03:22 PM
Ahhh okay i get it now so why do people cut the inner wings back and fit brace bars
#10 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 28 February 2015 - 03:36 PM
Gives you better access to the engine etc but you do lose a lot of strength by doing that.
#11 Sammy5158
Sammy5158
  • 106 posts
Posted 28 February 2015 - 03:43 PM
Isit still mot legit and just about to remove my scuttle how do i go about doin that do i have to drilll out yhe spot welds
#12 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 28 February 2015 - 03:48 PM
Yes its MOT legal but as i said not strong and to be honest i would never recommend it. The scuttle is spot welded in place along the windscreen frame, one on each point where it sits on the inner wing and a couple down the flanges at each end. Its also spot welded to the scuttle closeout as well.
#13 Stu.
Stu.
  • 912 posts
Posted 01 March 2015 - 09:53 AM
My Heritage inner wing came with the crossmember reinforcing plate already on it, so depending on where you get one from you might not need to fabricate your own. Only speaking from my end, and Sonikks got acres more knowledge and experience than me so if I'm wrong please correct me :)
#14 Sammy5158
Sammy5158
  • 106 posts
Posted 01 March 2015 - 05:59 PM
Ive cut the front of the inner wings off now but should i grind the rest of or drill it out i dnt want to hack away without some help first lol
#15 Stu.
Stu.
  • 912 posts
Posted 01 March 2015 - 06:37 PM
You really need to remove the paint etc back to bare metal to expose the spot weld locations, then use a spot weld bit to drill each one out. Eventually you'll be able to remove the inner wing, but it might need to come out in cut sections if its difficult to remove in one go.
