Now you've got something clean to put in the engine bay, reckon you're gonna use more than a bucket of water to wash it when it's done?
Clubby Estate Goes 16V
#16
Posted 09 March 2015 - 10:03 PM
#17
Posted 10 March 2015 - 08:49 PM
Can't go wrong with a bucket and sponge!
#19
Posted 02 April 2015 - 08:14 PM
Well the pistons have arrived. I have taken the block and head to Specialist Components for all the machining work to be done.
So while all that is away I need to crack on with the gearbox. Got it stripped down and need to clean out all the bits of piston and valve! Got a nice new cross pin diff ready to go in.
#21
Posted 13 April 2015 - 08:13 PM
#23
Posted 22 April 2015 - 09:14 AM
Like Christmas morning only better.
#24
Posted 22 April 2015 - 09:50 AM
Good god that heads a thing of Beauty Josh!
What's all the weld round the ports though just out of interest?
#25
Posted 22 April 2015 - 11:28 AM
Isn't it!
The head had some damage to the flanges around the exhaust ports and some snapped studs which they have repaired for me. A common thing on these heads apparantley.
#26
Posted 22 April 2015 - 12:17 PM
Can't wait to see this lot together and working Josh.
Very nice
Ben
#27
Posted 22 April 2015 - 06:05 PM
Yup, I'm looking forward to this too. Lots of pics please Josh
#29
Posted 23 April 2015 - 11:35 PM
Edited by peter-b, 23 April 2015 - 11:36 PM.
#30
Posted 07 June 2015 - 02:03 PM
Well...
Was not done in time for the IMM so had to go with an old 1293 engine I had. IMM was absolutely brilliant. Now back to normal and have got back on the 16v engine when I've had a few spare minutes.
Got the gearbox all finished and back on, clutch etc all on. Got the head on the block -
Put the cams in but, have hit a problem -
The head is held down with 10 longer A+ head studs which I had to cut down about 5mm and chamfer the tops off, BMW head washers & A+ head nuts. It is still very close to the cams. On the front end of the cams the cams are a larger diameter and on the exhaust cam it is touching the head nut.
