1275 Engine Id
18 replies to this topic
#16 carbon
carbon
  • 2,590 posts
Posted 12 April 2015 - 12:53 PM
If it is surface rust then I would recommend spending some using fine (about 300 grit) emery cloth, as sometimes if the steel underneath is not pitted they can be brought back to life.
Also worth carefully checking the crank tail where the primary gear runs, as this does not get reground and if the rust is very bad here you may be better off going for a replacement crank.
#17 MrIan
MrIan
  • 125 posts
Posted 17 May 2015 - 09:09 PM
Bit of luck there as the primary gear was left on the crank and is fine !!!! Will try the emery cloth carefully and see what we get. Cheers!!
Edited by MrIan, 17 May 2015 - 09:10 PM.
#18 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 19 May 2015 - 01:22 PM
Would suggest you start on the main bearing nearest the primary gear as that tends to suffer the most from wear.
#19 carbon
carbon
  • 2,590 posts
Posted 21 May 2015 - 06:31 PM
+1 for 62S's comment, once you have cleaned up the main bearing at flywheel end have a look for a raised ridge in the middle of the bearing - this is exactly where the oil groove is in the main bearing shells.
If you can't see or feel a ridge then the crank may not need a regrind.
