Exhaust wrap
#16
Posted 19 July 2006 - 04:55 PM
I was using the thermotec stuff that you can buy from minispares. I think other factors that could have helped the first one rot could be that in the year I had it on, the mini wasnt used much (I was at uni) but it was stored in a garage.
The stainless one cracked because of the heat that the wrap reflected back. Then with the cycles of heating and cooling it cracked on one of the welds.
The maniflow guy mentioned that this cycle 'brought the carbon to the surface' although I didnt really get what he meant. It did look different, it was all blackened and rough, not at all like stainless!
#17
Posted 19 July 2006 - 05:00 PM
#18
Posted 19 July 2006 - 05:57 PM
#19
Posted 22 July 2006 - 10:42 PM
#20
Posted 23 July 2006 - 09:57 AM
#21
Posted 13 August 2007 - 10:43 AM
so if that is a bad idea, is something like spraying an exhaust with thermo paint, a good idea or will this have the same effect ?
#22
Posted 25 September 2007 - 02:45 PM
#23
Posted 25 September 2007 - 06:24 PM
#24
Posted 25 September 2007 - 07:00 PM
#25
Edited by Se7enS1ns, 25 September 2007 - 07:01 PM.
#26
Posted 26 June 2012 - 09:36 PM
you see, to make iron hard we add carbon. very hard steel (high carbon) has about 1% carbon. and any more and it becomes brittle. all these cycles of heating and absorbing carbon and reheating has impregnated too much carbon in the steel and thus has weakened it permantley.
i guess the only solution is to keep the pipe as cool as possible which means not using heat wrap!
im not qualified in anything, just work with metals for a living and made some observations. hope this makes sense and is near correct!
Edited by mrthumb, 26 June 2012 - 09:37 PM.
#27
Posted 26 June 2012 - 09:43 PM
#28
Posted 26 June 2012 - 09:46 PM
#29
Posted 27 June 2012 - 11:54 AM
