Coil-over kit / Wheels and arches
22 replies to this topic
#16 Clubby1275GT
Clubby1275GT
  • 1,176 posts
  • Local Club: Birmingham Mini Owners Club / Bruuuums Mini's
Posted 19 July 2006 - 11:00 AM
ive got GAZ adjustables on mine and rear-hi-lows, very hard bumpy ride, but handles pretty well!
kinda wish it was a little softer but the adjustment doesnt seem to do much!
#17 Frede24
Frede24
  • 39 posts
  • Local Club: None - yet
Posted 19 July 2006 - 11:23 AM
Well atm the moment its like that form me aswell. Just a wee bit more bumpy since is quite worn.
So there basically isn't anything wrong with the coil-overs, Robert just seem to have been a little unlucky.
Cloverleaf: Have you had any problems with you mounting points not being strong enough, or have you enhanced them aswell.
Because I kinda have doubts about modifing too much, they are pretty stricht with constructive changes here in DK. But if I don't have to enhance them, then it would be fine.
I think one might be able to get rid of the bouncing the clubman1275 talks about with coils. The problem about the corner weight wont be a problem since I know a guy who has a set of weights.
Jammy_Basturd: The coils you have fitted were they at a mini or a honda/vauxhall?
I have fitted coil-overs on a couple of cars, I think it is pretty easy. That is if you don't have to enhance/modify.
#18 Cloverleaf
Cloverleaf
  • 220 posts
Posted 19 July 2006 - 12:15 PM
Not had any problems with the mounting points as yet *touch wood* and they have experienced a lot of abuse including my last track day at bruntingthorpe where the car was bouncing soo much I dont think it was ever on 4 wheels :D
Also i think they have improved them since.
#19 Frede24
Frede24
  • 39 posts
Posted 19 July 2006 - 01:19 PM
Ok, I will have to consider that.
What wheel dimension are you driving with, because im not sure if the 7" rims are gonna be in the way if i install coil-overs? (on the inside).
I have just discovered that there are brackets included in the gaz coil set that huddersfield. But you are riding with the original ones?
#20 Cloverleaf
Cloverleaf
  • 220 posts
Posted 19 July 2006 - 03:58 PM
I have 7x13" Starmags, there is no problem with the fronts but i have a 1" spacer on the back to stop the inside of the tyre hitting the spring.
I do have the original brackets but they're modified for the bottom mount at the front. But as i said i think they have changed the bracket since I brought mine!
#21 Frede24
Frede24
  • 39 posts
Posted 19 July 2006 - 05:59 PM
Ok. I think i'll stick with the regular shocks and some hilos. I just found out its pretty hard to get the card through mot if it has changes like that.
Hope i haven't been to much of a bother...:D
by the way. cloverleaf what arches are you using? Because I would like som that can cover 7" deep dish but im not sure if Sportspack can.
If not then, have someone seen a place where i can get 13x6 deep dish superlites with black center?
Edited by Frede24, 19 July 2006 - 06:03 PM.
#22 deanymini
deanymini
  • 771 posts
Posted 20 July 2006 - 04:04 PM
sportspack arches will cover 13x7's. many people run on this set-up. in my opinion, the standard rover 13x6's look a little over arched to me
#23 Frede24
Frede24
  • 39 posts
Posted 20 July 2006 - 08:29 PM
Ok...Then I think i'll be the 13x7.
Just ordered for about 1000£ from minispares today.
Im pretty exited to see how long delivery time they have since i live i Denmark. The downside about such a large order, is that the delivery cost is about 85£ :(
