Foam On Firewall
16 replies to this topic
#1 TheOriginalSkunk
TheOriginalSkunk
  • 125 posts
Posted 01 April 2015 - 12:35 AM
hey
basicly i have a foam on the firewall on the engien bay and also foam on the inside looks crap! is it needed or can i pull it out?
i will get pics tomoro when i get home from work to help see what i mean
didnt no if it was heat sheild or sound proofing or what so id thought id ask first
#2 JewSkii
JewSkii
  • 218 posts
  • Local Club: Looking For One
Posted 01 April 2015 - 12:40 AM
Doesn't it normally have something like this? or was there foam under this?
#3 Mark G
Mark G
  • Just Joined
  • 15 posts
Posted 01 April 2015 - 01:29 AM
All of this will be soundproofing. Under the bonnet will be flame resistant but none is essential. Over time they will sag and collect moisture, its all cheap stuff to replace.
#4 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 01 April 2015 - 08:07 AM
When I restored my mini I dumped the under bonnet sound proofing as it looked messy and had retained moisture over the years and lead to a lot of bulk head rust. Now it is painted with a coating of body wax at the top Under the scuttle area, so I can see if anything is trying to take hold and nip it in the bud. The only thing with this was I believe the wiper motor was mounted on it so was loose in the bracket afterwards.I had to make up a rubber spacer out of an piece of old exhaust rear mount.
#5 TheOriginalSkunk
TheOriginalSkunk
  • 125 posts
Posted 01 April 2015 - 08:13 AM
cool cheers for help i will upload pics later just to make sure it is sound proofing
#6 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 01 April 2015 - 08:27 AM
Why not remove the old spongey stuff, treat any blemishes/rust etc and replace it with a Minispares soundproofing kit. It will be very noisy otherwise.
#7 JewSkii
JewSkii
  • 218 posts
Posted 01 April 2015 - 08:31 AM
Agreed about the noise part. You can also make one for cheaper too if you wanted to save a few $$
Edited by JewSkii, 01 April 2015 - 08:32 AM.
#8 RooBoonix
RooBoonix
  • 1,225 posts
Posted 01 April 2015 - 09:02 AM
I've just removed mine, admittedly the engine noise is quite loud, but not unbearable. I quite like it :P
#9 TheOriginalSkunk
TheOriginalSkunk
  • 125 posts
Posted 01 April 2015 - 11:53 AM
right do i need to remove engine to do this job? as that's something i cant do
#10 RooBoonix
RooBoonix
  • 1,225 posts
Posted 01 April 2015 - 11:57 AM
Nope, it is possible to rip out with the engine in place. May need a stanley knife for a couple of bits but it's a pretty easy job :)
#11 TheOriginalSkunk
TheOriginalSkunk
  • 125 posts
Posted 01 April 2015 - 01:00 PM
sweet i shall do that and i think my new carpet gets a felt sound proofing kit with that so i will just sound proof the inside
#12 fenghuang
fenghuang
  • 796 posts
Posted 01 April 2015 - 04:46 PM
When you rip out the old foam be careful you don't damage / dislodge any wiring.
If you're replacing the carpet, have a look in the ICE forum for SilentCoat. It will be much better than just felt/foam.
#13 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 01 April 2015 - 07:02 PM
I removed the engine bay sound deadening as it can trap water.
#14 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 01 April 2015 - 09:31 PM
On my 1275 i removed the engine bay piece but ive kept the sound deadening(as much as possible anyway) on the interior side and its not as loud as my 998 which has none at all :)
#15 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 01 April 2015 - 10:15 PM
Removing the stuff inside the car makes a very noticeable difference to noise, whereas the stuff on the engine bay side dosent really seem to make a huge amount of difference. As above the stuff on the engine bay side is also notorious for soaking up rain water, which in turn tends to corrode & rot the back of fuses boxes, causing all sorts of electrical problems.
