No 12V Ignition To Startermotor
Best Answer Thilemann , 03 April 2015 - 07:23 PM
The problem with the starter, was the big relay. It had a bad soldering, so after giving it some new tin, it was running again.
Messing so much with the relay, i accidentally broke a wire (It had obviously been repaired before), so after resoldering the wire back in place, the fuel pump was working again, and my mini was again running. Thanks to all who took the time, to help :)
Go to the full post#1
Posted 01 April 2015 - 10:42 PM
Posted 02 April 2015 - 03:19 PM
It could well be an issue with the starter relay inside the relay box. There is a black box which mounts to the left of the air box, two big connectors coming out of it. There are some relays in there, one of which is the starter. The fact that it starts and runs if you provide a feed to the starter motor directly, means that the other relays are OK - Main relay, fuel pump relay etc. Could be a faulty relay, burned out tracks on the circuit board, damaged wiring where the two connectors go into the box. I have had issues here where the wiring had chafed through on the clutch master cylinder pipework, in my case it caused a short which burned out tracks inside the relay box.
If you turn the key over the cranking position, can you hear a relay clicking inside this relay box?
Do you have an immobiliser on this car?
For a good description of how the relay pack works, have a read at this:
http://www.theminifo...-functionality/
Edited by carlukemini, 02 April 2015 - 04:20 PM.
Posted 02 April 2015 - 09:31 PM
Posted 02 April 2015 - 09:32 PM
Edited by Thilemann, 02 April 2015 - 09:45 PM.
Posted 02 April 2015 - 10:10 PM
FS
Posted 03 April 2015 - 06:46 AM
Posted 03 April 2015 - 07:09 AM
Multimeter, clipboard and a big cup of tea. Start with the earths first and then work back from the starter.
FS
Posted 03 April 2015 - 08:34 AM
Posted 03 April 2015 - 06:19 PM
Thilemann have you had any luck with our problem?
im really struggling to get to the bottom of this issue
electrics are not my strongest point and this really has me baffeled
Posted 03 April 2015 - 07:23 PM Best Answer
Edited by Thilemann, 03 April 2015 - 07:24 PM.
Posted 04 April 2015 - 02:04 AM
do you think this could be my problem?
thanks
Posted 04 April 2015 - 06:48 AM
I'm not really strong in circuit boards, but that looks pretty nasty! It looks like it has burned the connection. I would suggest you borrow a relay, and test it, before buying a new (I believe a new is 80 pound in UK, 110 pound here in Denmark). Again, i'm not pretty strong in curcuit boards, so double check before doing this. But i think you could actually solder a wire between the two points, and test it. (Or just connect it by holding a wire, and try and click the starter relay on the board, or make a friend turn the key). Be sure, not to put the board on any metal when power is connected. It could make a short curcuit.
Posted 04 April 2015 - 07:19 AM
I'm with Carlukemini on this one, it looks like either the MFU is faulty or the wiring to it is damaged.
FS
Edited by FlyingScot, 04 April 2015 - 07:21 AM.
Posted 04 April 2015 - 10:25 AM
Posted 06 April 2015 - 10:08 PM
Yeah, when my wiring shorted out on the clutch master pipe, it took out quite a few tracks on the board. I just bridged the gaps by scraping the masking off and soldering pieces of wire in place.
