Ignition Switch Mk4 - Now Broken!
No replies to this topic
#1 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 02 April 2015 - 04:36 PM
Hi Guys,
OK stripped down my steering column to paint
Removed Steering lock assembly & the round black plastic switch at the base of the barrel.
Worked fine...then stood on the aforementioned switch...not working fine!
I have stripped the switch down and I believe mechanically it is working ok, positions 1,2 then it springs back to position 2 after turning to 3.
2 ball bearings in place with springs & copper tails/feet in place and touching the base plate connections.
But when I now turn to position 2 there is no ignition light & position 3 obviously does not turn over the engine.
1. Can I easily 'hot wire' the switch temporarily to get the car started until I can source a new switch?
2. Is there an easy way with a meter to test the switch to try & get it working?
See photo - Wires:
White - Far Right
Green/white tracer - Top Middle
White/red tracer - Far Left
Brown - Centre
Regards
Simon
Edited by Bradshaw-s, 02 April 2015 - 04:40 PM.
