I do have one question though, from my understanding, most pipe flares are sae bubble flares. But the tube nuts on the master seem to be flat so din bubble flares? My understanding is that din is flat at the bottom where it meets the tube nut.
I had of the lines made up using the old tube nuts and it looks like they did a sae flare. Will that matter as I believe it will seat and seal regardless?
Edit: I looked at the lines of the diagonal split system that I removed that run from front to rear and those look like din. So some seem flat at the bottom others look like they could have been bubble both sides but have a din/flat type tube nut. Back to being confused
Edited by miniGTS, 07 April 2024 - 05:33 PM.
