My mini is doing funny things to me. I've finally got her running but the electrics for the wipers, lights and indicators is causing me troubles.
I currently have no hazard light switch attached to the car as it was broken. Will this make any difference?
Basically when I put my windscreen wipers on they work fine but once you try and put the lights on at the same time, they cease working. Almost as if all the current is going to trying to make the lights work, then if you indicate, the drivers side is fine but the passenger side goes mad. But if the lights and windscreen wipers are off, the indicators are fine.
I've got to all the earths on the passenger side under the reservoir, undone the plug, sanded the bulkhead and contact cleaned those earths with no luck.
I'm running out of ideas, thanks for your help! :)
Edited by Equinox1275, 12 April 2015 - 09:33 AM.
