Track Days..
23 replies to this topic
#1 b_sdaddy
b_sdaddy
  • 643 posts
Posted 14 April 2015 - 07:09 PM
Dear all,
with summer looming, I'm thinking about taking my min onto a track.
It's not 1380.
It's not even Stage 1.
It's a standard 998 Mk4 on 10".
So then? Why a track day.?
Just want to be able to drive it, with out worrying about oncoming traffic and speed cameras.
With a top speed of about 70mph, it's definitely not about the thrill - just about getting to know the car in a safe environment.
What I need is some advice on tyres: an hour round a track & near 100% of the mins limit, what will the tyres be like afterwards...?
I'(m aware that track day'ers take a second set. Will even my 998 require a second set..?
cheers
#2 Steve220
Steve220
  • 5,045 posts
  • Local Club: BMC
Posted 14 April 2015 - 07:21 PM
I love track days. Tyres will be fine, i've yet to destroy a set in a hand full of laps. They're always worth doing as i personally believe you learn more about your abilities and your car's handling characteristics!
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 14 April 2015 - 07:22 PM
Id advise buying a set of cheap mini wheels(as a second set) with decent tyres, then a decent set of wheels for during the week
#4 racingbob
racingbob
  • 3,061 posts
Posted 14 April 2015 - 07:34 PM
just don't get carried away, its easy to on the track
just do spirited driving and enjoy yourself
put a few more pounds in the tyres
#5 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 14 April 2015 - 07:48 PM
what about safety , rollcage etc
#6 vx220
vx220
  • 419 posts
Posted 14 April 2015 - 07:51 PM
Surely, let a few pounds out?
#7 coopdog
coopdog
  • 4,506 posts
Posted 14 April 2015 - 07:54 PM
or dont change it at all.......
youll learn how to drive your mini as it is on the road
#8 Cooperman
  • 23,286 posts
Posted 14 April 2015 - 08:07 PM
On a dry track use around 33 to 35 psi. If wet reduce to c.30 psi all round.
If you have adjustable dampers take them up a couple of clicks, but make the rears slightly softer than the front.
Fit top quality brake pads - recommend Mintex 1144. Otherwise brake fade will spoil the enjoyment.
Put in good oil such as Valvoline Racing 20w50.
Be careful on long right-hand bends unless you have a central oil pick up, as oil surge could finish off the main & big-end bearings very easily. If the oil light comes on or the gauge flicks down on a long RH bend, press the clutch down and brake to slow the car, then the pressure will come back up. Don't repeat the pressure drop or engine failure will occur.
#9 Earwax
Earwax
  • 488 posts
Posted 14 April 2015 - 08:53 PM
Don't forget to take out all the loose things in the car and boot, plus one for better brake pads or you will experience fade, check  for clean fuel and no breaking down at high revs BEFORE you go.... i see quite a few track days terminated early because of existing problems coming to light only at higher extended revs... be sensible remember you have to drive home   and enjoy...
#10 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 14 April 2015 - 09:26 PM
I took it to mean invest a bit more money rather than pressure - as in for track days, get slightly better, grippier tyres.
#11 mab01uk
mab01uk
  • 12,421 posts
Posted 14 April 2015 - 09:29 PM
(Video: Surfblue63)
"This is footage of the various Minis and Mini based cars that took part in the Mk1 Performance Conversions Action Day, held at Blyton Park in 2014. All types of classic Mini took part and various kit cars, there was a couple of Mini Sprints, some historic racers, vans and even a couple of Mini Metros."
The 2nd MK1 Action Day (2015)
To be held at Blyton Park, Lincolnshire over the weekend of Saturday 2nd & Sunday 3rd of May 2015.
Both days will feature track action, static displays, very special guests, displays of some unique Minis, trade stands & much much more.
http://mk1-performan.../action-day.htm
Edited by mab01uk, 14 April 2015 - 09:29 PM.
#12 SiZT
SiZT
  • 50 posts
Posted 14 April 2015 - 11:19 PM
Give the car a good going over, change the brake fluid and oil then get out there and have fun. You won't regret it :-)
#13 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 15 April 2015 - 02:14 AM
Don't brim it with fuel before hitting the tarmac, it'll only end up spilling out your cap and thats not even with any spirited cornering - just any cornering, anyone remember castle combe?
They should have a fuel pump on site so fill up enough to get there from home then top up on site, just over half a tank is all you need, remember you have a 998 so its good on fuel, no need to go round with a near full tank, save some weight there
Just have some fun especially if its your daily driver, try not to start putting too many mods on after which is aimed at the track as you might end up hating using it daily as it won't be the same car again, car and track cars are two different cars, one will always suffer being used in the others 'manor
As mentioned already, check over the car first, is it running sweet as as it stands now? would it survive a quick blast on the rolling road? if no then forget the trackday and get the car running at its prime first
#14 b_sdaddy
b_sdaddy
  • 643 posts
Posted 15 April 2015 - 04:33 AM
cheers all for your sound advice - off to Spa!
#15 jt19
jt19
  • 745 posts
Posted 15 April 2015 - 09:25 AM
I've booked one at bedford autodrome. Sen circuit. First weekend of may.
Can't wait!!
