Removal Of Engine Plate Rivets
18 replies to this topic
#1 John B
John B
  • 33 posts
Posted 18 April 2015 - 09:14 PM
Hi
I have had the cylinder block skimmed which has left the insert sections of the engine number plate rivets in the block which need to be removed to allow a replacement engine number plate to be re-riveted into the existing holes.
Can anyone advise me on how to remove the old rivet inserts to allow me to fix the new engine plate?
#2 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 18 April 2015 - 09:17 PM
Hi
Simply drill them out and use slightly larger rivets
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 18 April 2015 - 09:39 PM
The Scrivets (proper name) are harder than the cast iron block, making drilling them out difficult. As yours are now skimmed off flush just position new plate so that you can drill new holes in block avoiding existing rivets. Use standard Scrivets. Engine plate will hide old ones.
#4 A-Cell
A-Cell
  • 1,610 posts
Posted 18 April 2015 - 09:43 PM
New Scrivets are available from minimail
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 April 2015 - 06:06 AM
The old scrivets unscrew quite easily, you can usually grab the edges with fine needle nose pliers across the threaded section.
#6 Spider
  • 15,141 posts
Posted 19 April 2015 - 08:10 AM
Hi
Good luck with that!
Ideally, they should have been removed before machining. Actually, I'm a little surprised that the Machine Shop didn't remove them prior to machining as if they were doing so with a tipped tool, they usually break the cutting tip. Grinding's no issue though, but not many shops do this (too slow).,
#7 John B
John B
  • 33 posts
Posted 19 April 2015 - 10:26 AM
What would have been the drill dia used for the original scrivets?
#8 carbon
carbon
  • 2,590 posts
Posted 19 April 2015 - 04:00 PM
About 1/8 inch, will check next time I'm in the garage.
But in my experience they are very difficult to drill out.
#9 John B
John B
  • 33 posts
Posted 19 April 2015 - 04:22 PM
From your experience, is the problem obtaining a drill bit to cut the scrivet remnent out?
#10 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 April 2015 - 05:32 PM
That's what i did with mine. I was able to prise them out slightly with a very thin screwdriver and then twist them out with pliers.
I would say that i would rather not try drilling them!
#11 carbon
carbon
  • 2,590 posts
Posted 19 April 2015 - 05:45 PM
The size of the drillings for these engine plate rivets is 4mm on an old pre-A+ block
#12 phil hill
phil hill
  • 616 posts
Posted 19 April 2015 - 07:15 PM
More like impossible to drill out.
They are not intended to be removed, ever.   You could conceivably grind some flats onto the head and try unscrewing them, but that assumes you do this before you deck the block.
Why not try to stamp the engine number into the nice smooth surface left behind where the plate was previously ??
Phil
#13 Spider
  • 15,141 posts
Posted 19 April 2015 - 09:49 PM
Phil
Yes. Trouble is too, even if you do get the correct type of drill bit is it will wander off to the softer material around it.
#14 John B
John B
  • 33 posts
Posted 20 April 2015 - 12:20 PM
The scrivet heads aren't there, all that can be seen is the scrivet sections flush with the top of the
block
Photo attached.Attached File  SCRIVETS INSITU.jpg   68.59K   37 downloads
#15 A-Cell
A-Cell
  • 1,610 posts
Posted 20 April 2015 - 01:38 PM
looking at picture doesn't seem that they are flush with block. Try dans advice post#5. Otherwise my advice post #3 is the simplest
