I'd just position the plate over to the right. If you want it to be factory looking then you could try a small cutting wheel, say a dremel, to grind a slot in the remainder. Then unscrew. Or possibly position a nut over the remainder and plug weld it to the scrivet.
Removal Of Engine Plate Rivets
John B
, Apr 18 2015 09:14 PM
18 replies to this topic
#16
Posted 20 April 2015 - 02:03 PM
#17
Posted 20 April 2015 - 03:15 PM
The top of both scrivets are flush with the top of the block.
I think I will try to cut a slot in the top first & see if they will screw out.
Many thanks for all you help.
#18
Posted 30 April 2015 - 07:55 PM
Hi all
Tried the screwing out method on the cut scrivet as suggested but no luck with that.
So I knocked the scrivets a little deeper into the holes with a centre punch and made an indent on the top of the cut scrivets, purchased a 5/32inch top grade drill bit and drilled the two scrivets out, crisis over.
Now I have cleared out the two scrivet holes, does anyone know of a type of concave headed tool suitable for knocking in the new scrivets into the holes to secure the new engine plate on the top of the cylinder block?
#19
Posted 01 May 2015 - 05:33 PM
You use a hammer, they are very hard and don't flatten much. A ball-pein hardly contacts them at all so knocks them in very well with little distortion.
