Low Compression & Blue Smoke
19 replies to this topic
#16 Lytesben
Lytesben
  • 29 posts
Posted 25 April 2015 - 03:18 PM
Right just been and done a compression test. Results as follows:
Working from left to right (not sure which way around the cylinders are numbered  :shy: )
150
155
160
162
I then added some oil down the spark plug hole and tested each again. Working from left to right:
180
170
175
180
So at least I have a definite answer now with it being worn bores. As mentioned above, I might be able to get my hands on a Metro 998 A+ engine. Is anyone able to confirm whether this would drop straight in after changing the engine mounts and thermostat housing? I have read that there may be some changes needed in terms of the clutch arm but not sure?
#17 carbon
carbon
  • 2,590 posts
Posted 25 April 2015 - 03:55 PM
Cylinders 1&2 slightly lower than others, but reasonably consistent. Roughly how much oil did you put down the bores? Could be bores, might also be worn rings.
Changing to Metro 998 should be fairly straightforward, but the final drive ratio is also likely to be different to Mini.
#18 Lytesben
Lytesben
  • 29 posts
Posted 25 April 2015 - 04:02 PM
Yeah I thought that they were reasonable consistent as well. I put about a teaspoon of oil down each.
Either way is going to need a rebuild right? That sounds alright then, what difference would the final drive ratio have? The metro engine is complete with a gearbox as well.
#19 carbon
carbon
  • 2,590 posts
Posted 25 April 2015 - 04:28 PM
If you have the 998 engine number put it into Guessworks 'engine/box' decoder and it should tell you what final drive is likely to be fitted.
A lot of the 998 Metros used a 3.65, but HLEs used a 3.1 final drive. For general road use a 3.1 with a 998 would be about right.
#20 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 25 April 2015 - 04:37 PM
Those compression figures are great, very good sign, the next step is to pull the head for a refurb
Edited by cal844, 25 April 2015 - 04:45 PM.
