I have a 1990 rover mini 998 that was experiencing major electrical issues due to shorted/burnt wiring to to the last owner shorting it with aftermarket mods. I believe that the components were ok as I got it running by bypassing the shorted, fried wiring. I've rerun new wiring for the whole car with straight 12v (no relays) for simplicity sake and added terminal blocks to isolate each circuit to ease troubleshooting. I've left the Lucas electronic ignition amplifier in place. The starter turns over but the engine won't start. I tried arcing my lead off the distributor but don't see a spark. I tested and have power coming off of the ignition coil when the key is turned.
I think I may have bitten off more than I can chew. Do you think that this is due to the relays being bypassed or is something else? Thoughts?
P.s. I know I may have screwed myself here...
Bypassing Relays? 998 Cranks But Won't Spark
QED
, May 14 2015 08:52 PM
electrical engine
3 replies to this topic
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
